Wheely Posted October 15, 2017 Share Posted October 15, 2017 Hi All, As you might have read in another thread I am preparing my 6x6 Land Rover Defender for an overland trip across Africa. I am in Ghana at the moment. The chassis is in great conditions - I want to paint it as i will be staying on the coast for long. I have found the Jotun products here so will be applying jotamastic-87-aluminium (https://www.smlmarinepaints.co.uk/primers/jotamastic-range/jotamastic-87-aluminium) The bodyshell is still mounted - the truck will be raised from the ground and the Jotamastic applied in situ Few questions: -how shall i prep the surface of the chassis? would a thorough wash with a strong water jet be sufficient or shall i also wire-brush? -besides the chassis also the external lower part of the bodywork will be painted (the external part of the floor) + the axles - any advice on how to best do that? -it will be applied with airless gun - anything that I should cover to avoid it painting (e.g. calipers, fuel hoses, ..) -the local vendor told me that it can be atomised within the cavities (like you'd do with Dinistrol) - what are your thoughts on that? -Would applying a top-coat have any impact on the resistance of it? I don't mind the cosmetic look Thanks very much, Simone Quote Link to comment Share on other sites More sharing options...
Wytze Posted October 16, 2017 Share Posted October 16, 2017 Hi, A heated pressure washer would be your best option i think. it will steamclean the surface Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 16, 2017 Share Posted October 16, 2017 I would rub back the existing coating as well, with no key to stick to, the coating could just peel off.. Quote Link to comment Share on other sites More sharing options...
DC_ Posted October 16, 2017 Share Posted October 16, 2017 Easy option steam clean/jet wash. I didn’t have that option (well not really) but I went down the wire brush route. Yes it takes ages...... but I’d say it gives you better surface to paint. What are doing about the inside of the chassis? Quote Link to comment Share on other sites More sharing options...
