Td5 OBD?
Guest deleted
Guest diesel_jim
Anyone here who uses rovacom/blackbox solutions/etc type stuff to read the ECU's on Td5's.... do you know what type of OBD protocol Lr's use?
i think it's either one of:
ISO9141-2 or J1850PWM..... :blink:
I fancy a project to build an OBD interface to lay with my Td5 (i don;t think i'll be able to change any of the ECU maps, but it'll be interesting to have a poke around anyway!) found some sites that i've downloaded various OBD software from, but i need to build a serial PC to OBD socket interface.
anyone got any good tips on this?
cheers! :D
Guest diesel_jim
It's ISO (AFAIK all of the europena manufactuers are)
for good tools / free Sw look here: www.scantool.net
no you wont be able to touch the engine management. only read common fault codes & reset some.
Thanks HoSS! :D
so, how do the likes of rovacom etc manage to change engine management/alter injector codes/alarm settings etc, is it just the software that they use?
OBDII (required standard on all euro cars made after 1995) has some standard required commands/codes. On top of that manufacturers add their own specific commands & codes, which can only be accessed by thier software.
the standard codes are quite good info, you can see all of the engine operating parameters, and see & (sometimes) reset common faults.
