GKT Posted October 23, 2017 Share Posted October 23, 2017 When selecting 1st gear it’s easy to go into reverse. On top of the box are two springs. Are these the detente springs? The bearing on the first motion shaft has got a small amount of movement i.e hold the first motion shaft and get very slight sideways movement. Is this OK or should I replace the bearing? Can I pull it out without taking the ‘box apart? Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted October 23, 2017 Share Posted October 23, 2017 When you say easy?... Mine is miles off first. The two springs operate the gate that you pass through to make 1st and reverse almost different continents. Are they still attached? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted October 23, 2017 Share Posted October 23, 2017 Those two springs are the gate springs, they make finding reverse harder. If you find reverse instead of first then the gate isn't working, or the gear lever ball end is badly worn. Or the bracket holding the gear pivot is not firmly attached. The detent springs are behind the two little L shape brackets held down with two set screws each. They are either side of the gearbox top. Leave be, as have no bearing on the first/reverse thing. G. Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted October 23, 2017 Share Posted October 23, 2017 Sorry my error on the springs, meant spring! But, you get the just. Quote Link to comment Share on other sites More sharing options...
GKT Posted October 23, 2017 Author Share Posted October 23, 2017 Thanks everybody for replies. The springs look rusty so they have probably lost their tension so I’ll replace them. Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 26, 2017 Share Posted October 26, 2017 The flap that sits over the end of the reverse selector shaft should have two springs, not one. It has an adjustment screw that allows the flap to be adjusted closer or further from horizontal. The closer to horizontal it is set, the greater the resistance to the gear stick moving to the left. If you unwind the screw too far, then the stick won't be able to lift the flap and reverse will be blocked entirely (this can happen from vibration unwinding the screw if the locknut isn't tight enough. Quote Link to comment Share on other sites More sharing options...
GKT Posted October 27, 2017 Author Share Posted October 27, 2017 (edited) Snagger, thanks for your helpful reply. Edited October 27, 2017 by GKT Wrong spelling Quote Link to comment Share on other sites More sharing options...
