Ditch Driver Posted October 23, 2017 Share Posted October 23, 2017 Newbie to Land Rover Discovery II 2003 Window Regulator issue 10-23-2017 My window stopped closing and seemed to come off the track, I can slide it up and down by hand. When i took the regulator out the quarter circle gear on the regulator the motor gear rides on had broken spot welds and fell off. I purchased a new regulator and installed keeping the old motor, with the old regulator missing the gear I was unable to orient the new regulator to its correct location for up and down. I installed and reinstalled 7 or 8 times trying different orientation for the gear location but the window will only go up about half way and stops. there seems to be nothing restricting its movements, the motor just stops raising the window at the half way point. Starting to think it is a bad motor even though is runs smooth and quiet. Anyone have thoughts or experience with this issue? Quote Link to comment Share on other sites More sharing options...
bear Posted October 24, 2017 Share Posted October 24, 2017 Hi, Have you had a look at this How To video. Might help http://www.roverparts.com/resources/videos/repair-window-regulator-motor-discovery-ii/ Griff Quote Link to comment Share on other sites More sharing options...
