simonpelly Posted October 24, 2017 Share Posted October 24, 2017 Hi Folks, Bit of digging suggests that the connector highlighted in the picture is C786 - Main harness to air conditioning unit behind the fuse unit. Thinking that it might be a useful connection for some auxiliary kit - it has both power and aux power. Found a compatible connector from Kojaycat Automotive - 4W-CNA-NAT Anyway, the question is how best to find a negative source without splitting current wiring harness. Thinking it might be better to run back to the battery. However, are there any other convenient negative connections under the dash (current dash fully taken out). Many Thanks, Simon... Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 24, 2017 Share Posted October 24, 2017 Any bit of body work would be fine. I usually run any earths to the closest screw/bolt. Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 25, 2017 Share Posted October 25, 2017 As VB says, I'd just make a ring connection and connect it to one of the bolts that secure the fuse box to the bulkhead, but if you're running cables a direct earth wouldn't do any harm, I've got a habit of running an extra cable in a bundle just in case. If you're planning on using for big current stuff then I'd edge towards running a earth directly back to the battery. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted October 25, 2017 Author Share Posted October 25, 2017 "ring connection and connect it to one of the bolts that secure the fuse box to the bulkhead" - Great idea. It's not for high current. Many Thanks all for replying, Simon... Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 26, 2017 Share Posted October 26, 2017 An alternative - drill a small hole in the fuse panel in a space and nut/bolt earth in place, I think my 86 truck has a standard earth here in a similar way. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 26, 2017 Share Posted October 26, 2017 An M6 bolt through the bulkhead at a safe & convenient point - you can get a lot of 6mm ring terminals on it. Give it a smear of vaseline or waxoyl /dinitrol etc. (AFTER connection) to prevent corrosion. Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 26, 2017 Share Posted October 26, 2017 urmm the fuse box bolts to the bulkhead? why need to drill any more holes etc... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 26, 2017 Share Posted October 26, 2017 5 minutes ago, reb78 said: See my post - the panel it bolts to isnt a good earth point IMO Now I know its been a while since I took it off.... but I'm sure my fuse panel bolts right to the bulkhead?! Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 26, 2017 Share Posted October 26, 2017 Haha. I think you might be right thinking about it!! Maybe a mod can delete my posts!! Doh! Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 26, 2017 Share Posted October 26, 2017 19 minutes ago, reb78 said: Haha. I think you might be right thinking about it!! Maybe a mod can delete my posts!! Doh! You've been driving your D2 too much.... Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2017 Share Posted October 26, 2017 9 hours ago, reb78 said: Haha. I think you might be right thinking about it!! Maybe a mod can delete my posts!! Doh! Done Quote Link to comment Share on other sites More sharing options...
simonpelly Posted October 29, 2017 Author Share Posted October 29, 2017 Genius idea. Will use the fuse bolts as suggested. Thanks, Simon... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 30, 2017 Share Posted October 30, 2017 Wouldn't be hard to run a wire from the battery negative to the bolt and make a really good earth that not reliant on rusty nuts and bolts to get back to the battery. Just a thought Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 30, 2017 Share Posted October 30, 2017 I'd also be trying to run a big earth separately. Anything to try and reduce the electrolytic corrosion in the body. Quote Link to comment Share on other sites More sharing options...
