Roosterrs Posted October 28, 2017 Share Posted October 28, 2017 I have been having an intermitant fault on my 1997 300 TDi Defender 90. In the past 6 months it has failed to start about 6 times. Turn the key and nothing happens. This usually occurs after a long run so I was thinking it may be a heat issue. Today it happened again and after 45 minutes to let it cool down it still wouldn't start. In the end I bump started it and it has been fine ever since. I connected my volt meter up to the starter exciter wire and get 8.8 volts at position 2 and then around 9.75 volts when the relay clicks, when I turn the key to the start positon I get about 11.5volts. The vehicle is starting fine again though. Vehicle has done 125K miles. I am thinking its the spider or maybe the starter motor. Spider seems favourite but just wondering if the starter is going and hitting a sweet spot each time it wont start. Does the AMR4956 bypass wire fit a defender? Any ideas anybody? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted October 28, 2017 Share Posted October 28, 2017 Yes the AMR4956 can be fitted to a Defender,you can even fit it inside the black box if you want.I'd drill the rivets out and inspect the spider,you can usually see a bad soldered joint on the board that causes the non start issue. Quote Link to comment Share on other sites More sharing options...
Roosterrs Posted November 12, 2017 Author Share Posted November 12, 2017 Starting problem happened again today, luckily at home. Got the multimeter out and connected it to the starter excitor lead. I had 8 volts at ignition switch position 2 and 10 volts at position 3. This isn't twelve volts, but does this rule the spider out and sound like a starter motor problem? Quote Link to comment Share on other sites More sharing options...
