rrcflip Posted November 5, 2017 Share Posted November 5, 2017 (edited) Hi everyone I'm new in the lr4x4 community but i'm reading you guys since i first tought to convert my 3.5 flapper efi range rover classic. I Read tons of 3Ds in this megasquirt section and i'm now aware of what going to megasquirt means. I still have a lot of doubts concerning wiring and how to properly tune it but the biggest is whether I can convert my range rover (after the megasquirt install) to lpg with a "piggyback" lpg injection system as this is the only way to have lpg injection here in Italy where I live. thank you guys for your help filippo Edited November 5, 2017 by rrcflip Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 5, 2017 Share Posted November 5, 2017 2 hours ago, rrcflip said: as this is the only way to have lpg injection here in Italy where I live. Why is that? Legally? There's no reason it shouldn't work, but why not just let Megasquirt drive the LPG injectors directly? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 5, 2017 Share Posted November 5, 2017 Given the lpg system just picks up the injector pulses and uses this to drive the log injectors with a modifier, I can't see why it wouldn't work at all, it is the same as any other efi ECU Quote Link to comment Share on other sites More sharing options...
=jon= Posted November 19, 2017 Share Posted November 19, 2017 It should work - this is the route I'm going down shortly. You can also run a second map on the the MS for fuel/spark just for LPG and fine tune the LPG map, probably better than you could with the LPG ECU.. Quote Link to comment Share on other sites More sharing options...
rrcflip Posted December 15, 2017 Author Share Posted December 15, 2017 hi everyone! i'm very sorry for my late reply but I have been sick and I had no time to look at the forum! @elbekko yes. actually legally I can't convert to megasquirt either..... the other reason is that I fear i wouldnt be able to run both lpg and petrol with the megasquirt.....eheh Quote Link to comment Share on other sites More sharing options...
