ajh Posted November 10, 2017 Share Posted November 10, 2017 Are there rear door skins for D1 available anywhere? It has reached the point where none of the ones I can find are in good enough shape to restore. Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2017 Share Posted November 10, 2017 chuck a email to https://www.rimmerbros.co.uk/Item--i-GRID010053 door skins listed on the website. Quote Link to comment Share on other sites More sharing options...
ajh Posted November 10, 2017 Author Share Posted November 10, 2017 That was the first google hit... and no, no rear door skins there only a full shell... which is worth more than most of the rest of the vehicle. Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2017 Share Posted November 10, 2017 I can only find the door shell with outer skin fitted too, so don't know if anyone can supply the outer skin panel as a seperate item. certainly not listed by LR Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 11, 2017 Share Posted November 11, 2017 Depending how keen you are, the lower part shouldn't be too difficult to make from a sheet of ally, assuming a '97 is not a steel skin. The cut out for the door handle could be the hardest bit. The top and vertical sections are separate parts, and I've not seen so many rot of there. Quote Link to comment Share on other sites More sharing options...
