Flash17 Posted November 10, 2017 Share Posted November 10, 2017 Hi all, Can i pick you collective brains please? I have a badly worn sailsbury dif in a ex mod v8 110 and a spare SIII (I think as it has leaf spring clamps and is not as wide) Salisbury axel with a barely worn diff, I Know the whole axel is not interchangable, and I know the diff carrier looks about the same size, I know ring gears and pinions are matched pairs, and I know I would have to do a set up from scratch with new shims and crush tube etc. However what I don't know is, are the ring gear and pinions interchangable between a 110 and a series 3 sailsbury axel, if not does anyone know the ratios of either or. Any advice/wisdom would be greatfully received. many thanks in advance. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 10, 2017 Share Posted November 10, 2017 Ratio is different. 4.7 on a Landrover and 3.54 on most early coil spring JLR products. Rest is interchangeable. G. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted November 11, 2017 Share Posted November 11, 2017 They are 4.7 ratio on the leaf sprung and the carriers are different I will have some 3.54 r&p for sale soon if your that worried Quote Link to comment Share on other sites More sharing options...
Flash17 Posted November 14, 2017 Author Share Posted November 14, 2017 Many thanks for the words of wisdom, looks like a perfect excuse to go looking for a disc braked sailsbury then! Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted November 19, 2017 Share Posted November 19, 2017 On 14/11/2017 at 11:32 PM, Flash17 said: Many thanks for the words of wisdom, looks like a perfect excuse to go looking for a disc braked sailsbury then! I've got one lying at my parents if you're interested. Can also scrounge up some hub assemblies and new discs. [edit]Also have a prop from mine in good nick - all came off a 300Tdi 110 with R380 and LT230[/edit] Quote Link to comment Share on other sites More sharing options...
