Range rover classic differentials
Rrc19933
I'd suspect the lash to be between the drive flanges, and the half shaft or just a worn halfshaft.
Don't just assume it is the diff.
Actually setting them up is involved but certainly doable DIY.
If it is the diffs, I used this to set up my diff when I swapped CWP on an ARB. Ignore all the ARAB bits, but the measuring and dial gauges etc is all good.
http://www.landroverclub.net/Club/HTML/ARB_Locker.htm
