ianmayco68 Posted November 15, 2017 Share Posted November 15, 2017 Hi all , looking for any recommendations on upgrade bonnet catches i’m on my second genuine one in 8 months so looking for a better solution. Have seen aero catches but read good and bad about them , has anybody any other solution. It’s a daily driver and will be used for greenlaning. cheers Ian Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 15, 2017 Share Posted November 15, 2017 This sort of thing is very simple, and won't get clogged with mud, bit retro, if you like that sort of thing http://uk.rs-online.com/web/p/products/3399151/?grossPrice=Y&cm_mmc=UK-PLA-DS3A-_-google-_-PLA_UK_EN_Enclosures_And_Storage_And_Material_Handling-_-Cabinet_Hardware-_-PRODUCT+GROUP&matchtype=&gclid=CjwKCAiA6K_QBRA8EiwASvtjZYYLYxEXGVYWM6ia4hk6w_GaVn4MYL_zMxVKIn9t6eB2r4X1IDhkEhoCeQoQAvD_BwE&gclsrc=aw.ds Not sure how big they need to be, but gives you an idea. How is the original one failing? Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 15, 2017 Share Posted November 15, 2017 Man if you're going reto... Camel's have these and they work perfectly well. http://www.ebay.co.uk/itm/2-x-BONNET-FASTENER-CATCH-MILITARY-FOR-LAND-ROVER-SERIES-MRC5314/253124225503?hash=item3aef6129df:g:G44AAOSw~RNZpspg As Bowie eludes too... what's going on with the present one? its not a common thing you see problems with... Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted November 15, 2017 Author Share Posted November 15, 2017 1st one rivet in the arm came out and arm broke and this one you push it down it locks put your fingers under the bonnet and you can’t lift it start engine driving along and it pops up, have tried adjusting the striker which there is still travel on when locked and you push the bonnet down , all parts are new . When it’s locked and you use the bonnet release it works as should don’t know what else to try? Quote Link to comment Share on other sites More sharing options...
