truckcab Posted November 18, 2017 Share Posted November 18, 2017 1995 Defender 110 CSW, this problem has been covered before but I thought it might be useful to share how I resolved this problem on my vehicle. My dipped beam was not working so after checking the fuses, main lighting switch (S100), Relay-Dim Dip(R126), Relay-Headlamp(R123) I then checked the Switch-Column(R123) and found that the connection between C036-1 and C036-6 was faulty, this was due to the blue wire (C036-1) coming loose on the copper strip which has the contacts. Made a temporary solder and this solved the problem. Will fit a new switch as not 100% sure the solder will hold over time. See wiring diagram for 1997 Defender. Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2017 Share Posted November 18, 2017 Fit a set of relays to handle the higher current side of the switch/headlights, the main light switch only has to operate the relays then, one for dip & one for main beam. Quote Link to comment Share on other sites More sharing options...
supaimpy Posted November 18, 2017 Share Posted November 18, 2017 https://www.ebay.co.uk/itm/H4-9003-Wire-Harness-Relay-Halogen-Headlights-Lamp-Booster-Set-with-Fuse-Base/400945263986?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 try this Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted November 19, 2017 Share Posted November 19, 2017 Hmm.. and hope that one fuse doesn't pop when your going round a busy roundabout or a corner on an unlit country lane. On the original wiring all of the filaments are individually fused for a reason. Quote Link to comment Share on other sites More sharing options...
