reb78 Posted November 22, 2017 Share Posted November 22, 2017 (edited) Can anyone tell me what's in the top end gasket set STC1172 for the 200tdi? I can make some of the components out from the pictures online but other bits I'm not sure about and none of the suppliers I've emailed today seem to want to tell me what the kit actually consists of. Edited November 22, 2017 by reb78 Quote Link to comment Share on other sites More sharing options...
western Posted November 22, 2017 Share Posted November 22, 2017 200tdi top gasket set https://www.turnerengineering.co.uk/stc-1172-gasket-set-top-c2x20634834 hover over the small photo & move cursor around it & it'll put up a bigger one you can see the contents of the pack. inc --- manifold gasket, rocker cover gasket & 2 x semi circle plugs, valve stem seals, turbo to manifold & exhaust downpipe metal gaskets, thermostat to head & top cover to lower section gaskets, various copper washers for fuel spill return banjo bolts, injectors to head. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted November 22, 2017 Share Posted November 22, 2017 Ive got the majority of the contents of 2 richard. if there's anything specific you want, just shout. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 23, 2017 Share Posted November 23, 2017 All you'll need Rich is in the top end set with the addition of the head gasket itself. Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2017 Share Posted November 23, 2017 Ensure you order/buy the correct thickness head gasket, usually the same as existing but could be different after changing pistons. Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 23, 2017 Author Share Posted November 23, 2017 Thanks All. I don't understand why the retailers cant list the contents, but your say so will do for me. One replied to say there wasn't a list (well hows about creating one??) and noone had ever complained, the other I contacted hasn't got back to me. Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 23, 2017 Author Share Posted November 23, 2017 The current head gasket is a zero hole gasket Ralph - no change of pistons, so I will just order the same again. 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2017 Share Posted November 23, 2017 The no hole is the thickest, I had to use one of those on my rebuild. Hope it all goes together ok 👌 Quote Link to comment Share on other sites More sharing options...
