inchman Posted November 25, 2017 Share Posted November 25, 2017 hi all, im in the process for putting my 2004 110 td5 on the road and preparing it of laning etc, nothing extreme. i have a 24 spline truetrac currently fitted to a disco one rear axle, my question is its the truetrac unit transferable between these diffs. Also fitting it to the rear axle of the 110. thanks in advance and sorry if the question has been asked before but i could find the answer while searching. cheers Gary Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 25, 2017 Share Posted November 25, 2017 Nigel from xcess4x4 will know for sure. The Wolf/P38 type diff in your 110 is different to the Disco 1 long-nose type. I can't remember which way round but one can be fitted to the other with some machining, and I'm sure it's the P38 that can be machined to fit the D1/RRC/Defender. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 26, 2017 Share Posted November 26, 2017 You need a spacer ring. http://www.ashcroft-transmissions.co.uk/diy-rebuild-kits/p38-type-differential-rebuild-kits/p38-spacer-ring.html Quote Link to comment Share on other sites More sharing options...
