mcc1979ian Posted November 28, 2017 Share Posted November 28, 2017 Ok so when driving to work yesterday morning at 0330hrs the old girl suddenly jolted like something grabbed on hard then struggled to move freely whilst reekin o clutch then I took it easy for the last couple o mile and it seemed ok. Iv never had a chance to get back to it as I’m now away all week. Anyone got any recommendations where to start lookin? Cheers p.s it’s a 300tdi attached to LT77 on 1.2 transfer Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 28, 2017 Share Posted November 28, 2017 Handbrake? Quote Link to comment Share on other sites More sharing options...
110 V8 Posted November 28, 2017 Share Posted November 28, 2017 Collapsed wheel bearing?? Andy Quote Link to comment Share on other sites More sharing options...
cackshifter Posted November 28, 2017 Share Posted November 28, 2017 Yeah I'd go with handbrake initially, having had similar experience. Maybe it wasn't clutch you smelt. See if there are signs of heat on the drum, like no paint. In any case that's the easiest thing to check first. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted November 28, 2017 Author Share Posted November 28, 2017 Cheers, will give it a check when I get home. I actually don’t think it was correctly adjusted when I had the gearbox sorted. Came back and was very very tight and handle only lifted a few clicks. I installed a new cable before the gearbox was done and had it set so it still came almost all the way so that could be the issue. If it is the lad at the garage gona be gettin an ear bashing. Box came back still leaking oil and clutch slipping worse as when it went in and now this 😡 Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 28, 2017 Share Posted November 28, 2017 I'd vote for handbrake too. Worth checking the engine earths: I've seen a handbrake-cable that's served as an "emergency earth" and carried the full starter-motor current. Let's just say it was *extremely* sticky, to the point where the pull-off springs inside the H/B drum sometimes struggled to pull the shoes back properly. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted November 29, 2017 Share Posted November 29, 2017 On 28/11/2017 at 10:01 AM, 110 V8 said: Collapsed wheel bearing?? Andy I had this at 65mph. Felt like being shoved in the back. Hard to detect when stationary without jacking up each wheel Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted November 29, 2017 Author Share Posted November 29, 2017 Mmm my only thought with a wheel bearing would be, why the smell of brake/clutch. Will check everything over at the weekend and hopefully solve it then when it goes back in to get it’s gearbox/transfer/engine or whatever oil leak properly sorted I’ll remind them not to adjust my handbrake this time Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 29, 2017 Share Posted November 29, 2017 If your bearing has collapsed sufficiently your brake material could end up rubbing? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 30, 2017 Share Posted November 30, 2017 10 hours ago, mcc1979ian said: Mmm my only thought with a wheel bearing would be, why the smell of brake/clutch. Will check everything over at the weekend and hopefully solve it then when it goes back in to get it’s gearbox/transfer/engine or whatever oil leak properly sorted I’ll remind them not to adjust my handbrake this time Or the liquorice mark you leave on the road.....obviously I don' know this from experience Mike Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted November 30, 2017 Author Share Posted November 30, 2017 Lol. Surely if it collapsed that bad it would affect the handling though Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 1, 2017 Share Posted December 1, 2017 Could be anything in the drive train really. I had something similar when the crownwheel bolts undid on the front diff. Mo Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted December 4, 2017 Author Share Posted December 4, 2017 Slackened off the handbrake cable at the weekend and took it out for a good run. Seems ok now and the clutch isn’t slipping as much. Now she’s gone back to garage to get the leaks hopefully fixed properly this time Quote Link to comment Share on other sites More sharing options...
