Dave64 Posted December 5, 2017 Share Posted December 5, 2017 Hi Guys, Sorting out a bit of wiring/plumbing on this TDI 200 12L engine, what is this device, what does it do and where does it go to? Still waiting for a mate to photostat me a few pages from his workshop manual, got most of it sorted, can't seem to find just where the end of this cable/hose is supposed to go. Flying blind at the moment. Looks like either a breather of some sort or a plug that hooks up to something or other. Any help appreciated, Cheers, Dave64 Quote Link to comment Share on other sites More sharing options...
Wytze Posted December 5, 2017 Share Posted December 5, 2017 looks to me like the vacuumpump? and should go to the booster for the brakes. Quote Link to comment Share on other sites More sharing options...
western Posted December 5, 2017 Share Posted December 5, 2017 That is the vacuum pump for the brake servo, the hose from the top cover must go to the non return valve connection on the brake servo front face. you can see the route of my hose on my defender spec 200tdi. [hose marked mkperformance] Quote Link to comment Share on other sites More sharing options...
Dave64 Posted December 6, 2017 Author Share Posted December 6, 2017 Thanks, Guys. Not running any type of vacuum booster, so I take it is safe just to blank that line off at the canister affair?? Dave64 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 6, 2017 Share Posted December 6, 2017 If your going to blank it off I would lift the lid and remove the vanes to stop it drawing a vacuum. Mike Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted December 6, 2017 Share Posted December 6, 2017 'Canister affair' is not a term I recognise, so I cannot, with confidence, answer your question directly. If you don't need the vacuum you should blank off the inlet to the air pump, otherwise, instead of drawing air from a brake servo (and thus creating the necessary vacuum) the pump will draw air from the atmosphere into the crankcase, resulting in oil laden air emitting from any opening it can find. Regards. Quote Link to comment Share on other sites More sharing options...
Dave64 Posted December 6, 2017 Author Share Posted December 6, 2017 Thanks men. Quote Link to comment Share on other sites More sharing options...
