drive by wire 300 Tdi swop
Right, as the Hybrid's build is very slowely progressing, another project just arrived.
I need to fit a 300 Ex. disco with ZF mounted to it into a 110 with a to be rebuild 300 Tdi.
Obviously, the flywheel needs to be replaced as the 110 is a manual one.
The injector pump on the "new to me engine" is drive by wire.
Am I right in thinking I can swop the top bit on the injector pump to make it drive by cable ?
I think so, but if not, you could swap the pumps over.
2 hours ago, Snagger said:
That's what it means - electronic throttle rather than mechanical.
Still a different thing. I only remember a throttle cable with a TPS on top of it. Hence my question, was there a 300TDi without a throttle cable but with an actuator?
Yes, I think so, the TPS version was the EGR-equipped vehicles, and then the EDC is the pump fitted to auto Discos, which you can 'tune' with a 'chip', so must do more than just have a TPS:
https://www.allisport.com/shop/performance-products/tuning-units/allisport-electronic-tuning-unit-for-discovery-300-tdi-edc-models/
(Not a recommendation, just showing!)
They also have a MAF: https://www.ebay.co.uk/i/162597477502?chn=ps&adgroupid=47842945425&rlsatarget=pla-380312380491&abcId=1129946&adtype=pla&merchantid=113383971&poi=&googleloc=9045660&device=c&campaignid=974959912&crdt=0
Yep.  My RRC has an EGR equipped 300Tdi - it has a sensor, seemingly like a potentiometer, fitted over the throttle quadrant and wired to the EGR solenoid.  It has nothing to do with commanding throttle positions; it just commands the solenoid to close the EGR valve as the throttle is opened.
