western Posted December 11, 2017 Share Posted December 11, 2017 Is it possible to replace the front diff pinion bearing in situ, (diff fitted to vehicle) ? I know I can replace the seal, but just not sure if the bearing can be changed without removing the diff. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 12, 2017 Share Posted December 12, 2017 The one closest to the seal? I think you'll struggle as you won't be able to move the pinion out of the way? Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2017 Author Share Posted December 12, 2017 yes the bearing at the prop flange end Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 12, 2017 Share Posted December 12, 2017 That bearing will affect the preload and would be a tricky but not impossible job on the LR. If the pinion bearing is failing, the head and carrier probabaly not far behind .... N Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2017 Author Share Posted December 12, 2017 My reason for asking was a horrid screech, which I thought I had found [transfer box end UJ of front prop was giving up, that UJ has just been replaced but prop not refitted yet] on the way home from work yesterday the screeching stopped, so I reckon it was a unseen stone caught in one of the front disc/calipers, I also have a new diff pinion seal [behind prop flange] to fit, which I can do fairly quickly, so now the screech has gone it wasn't the pinion bearing after all, it was quiet going to & from work today a round trip of 30 miles, so reckon its fine. Thanks for the info. its not the original diff, I replaced the complete unit some time ago. Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2017 Author Share Posted December 13, 2017 Front diff was quiet again today so reckon it was definitely a stuck stone in caliper, I replaced the pinion seal & refitted the front prop, so that should be all good now, it's well lubricated as is the front diff, I'll stick the grease gun on a bit more often. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 13, 2017 Share Posted December 13, 2017 I can't see how you would pull the race out. Normally, the inside bearing is what fails anyway as it is highly loaded. The outer bearing does not do much. Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2017 Author Share Posted December 13, 2017 Seems its all good, no nasty screechy noise driving to/from work today, so with the new pinion seal in place & diff oil topped up, I'm happy it'll be fine. Quote Link to comment Share on other sites More sharing options...
