ThreeSheds Posted December 24, 2017 Share Posted December 24, 2017 I have alloy wheels on my Disco 2, and the nuts have corroded under the caps, meaning that I can't get my impact socket on them without a struggle. (I have to use a rattle-gun to undo my wheelnuts since I am not as strong as I used to be). I don't particularly want to replace them with the same so... A while ago I found some wheelnuts for sale on ebay that were intended as replacements for the standard alloy-wheel nuts with the silly cap thing, but were solid machined steel, but now I can't find them. Can anyone help please? I guess as an alternative I could buy the normal ones and boil them in Linklife before use - that should stop them corroding Quote Link to comment Share on other sites More sharing options...
miggit Posted December 25, 2017 Share Posted December 25, 2017 Have tried looking for range rover wheel nuts? My L322 had plain black steel nuts without those silly caps... but you'll need the know which nuts you've got... they come in 20mm wide and 22.5mm wide. From what I can remember they should be the 22.5's.. but don't rely on my memory ... I was around before they invented mobile phones, soap you washed with.. not watched, and surfing required the sea... not a computer!! Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted January 28, 2018 Share Posted January 28, 2018 Beware thst a lot of the aftermarket wheel nuts are nowhere near as strong as the OE nuts. They'll be strong enough to retain the wheel, but can be much more sensitive to cross threading - especially with a rattle gun. From personal experience, they appear softer & not so well heat treated. I have to make sure more threads are engaged & running smoothly vs OE nuts before using the impact wrench. I only use the wrench to spin them down fast, then use a torque wrench to finalise tightening. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 28, 2018 Share Posted January 28, 2018 Rattle guns kill the alloy nuts even without any corrosion underneath, the caps get deformed and you then have a hell of a job to get the socket on (or off). Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted January 28, 2018 Share Posted January 28, 2018 On 24/12/2017 at 11:26 PM, ThreeSheds said: ... A while ago I found some wheelnuts for sale on ebay that were intended as replacements for the standard alloy-wheel nuts with the silly cap thing, but were solid machined steel, but now I can't find them. Can anyone help please? ... Possibly MisteR Tee or possibly Wrington Engineering. I haven't used either. Regards Quote Link to comment Share on other sites More sharing options...
miggit Posted January 28, 2018 Share Posted January 28, 2018 The only solid (capless) wheel nuts that I've been able to find are either 20mm or 22.5mm shank, which means that they are for D3/4, L322 and RRS, it looks like you can only get the capped type for the D2 / P38 Wrington might be able to make a set, as they are basically a RRC wheel nut with a smaller thread... Typical of LR to shrink the thread size and then wait a model run to shrink the wheel nut size... If you really must have solid wheel nuts you could always upgrade to the later alloy wheel, there are a lot of cheap 18" sets on the market as most peep's are changing them for rubber bands... fools! Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted January 29, 2018 Author Share Posted January 29, 2018 14 hours ago, miggit said: The only solid (capless) wheel nuts that I've been able to find There are these, but they are rather expensive: http://www.ebay.co.uk/itm/Set-of-20-x-M14-x-1-5-27mm-Hex-Alloy-Wheel-Nuts/172202468700?_trksid=p2485497.m4902.l9144 Quote Link to comment Share on other sites More sharing options...
