Gazzar Posted January 6, 2018 Share Posted January 6, 2018 Quick question, how integrated is the abs/HDC/TC system in the P38? Would it operate independently, or does it need the bcm and the like to be on the bus? I need a stand alone system for a project. G. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 6, 2018 Share Posted January 6, 2018 The RRC system is standalone, and you can update it with the P38 pump and sphere which appear more reliable. Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 6, 2018 Share Posted January 6, 2018 It's pretty much self-contained. It has outputs to a few other ECUs, but no inputs. See: RAVE, (70) Brakes - ABS, ECU connector pin details. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 6, 2018 Author Share Posted January 6, 2018 Perfect. Thank you. G. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted January 7, 2018 Share Posted January 7, 2018 Just remember that 95-99 P38's are four wheel ABS,but only TC on the rears.If you want 4 wheel TC then you need the 99-02 type with the smaller black ecu.(Not as reliable) Quote Link to comment Share on other sites More sharing options...
Tanis8472 Posted January 11, 2018 Share Posted January 11, 2018 Some had no TC at all. Quote Link to comment Share on other sites More sharing options...
