Mc071963
285/75 R16's on a Defender 90
Same tyres on modulars. I really like them and would have to be pushed to change.
Mike
  • Like 1
Share this post
Link to post
Slight lift mainly due to the winch but it did rub occasionally on the back before. Steering lock stops need adjusting to stop the tyres rubbing the radius arms. I don't know what offset the challenger wheels are but the modular (16x8) stick out father than standard wheels.
Mike
Share this post
Link to post
not sure of the lift the springs are rrc red and whites but the rims are challenger and the tyres are 285/75 /16 km2
Share this post
Link to post
I had modulars on before with the same tyres the challengers I got have more off set so I was able to get some decent steering lock back
Share this post
Link to post
If they really have a 35 mm offset, I would expect the tyres to hit the spring perches.  With a more normal 10 to 15 mm offset, they will be fine.  The tyre is about as big as you can go without trimming the arches.  Spring lifts don't change the tyre clearance.
Share this post
Link to post
The website says they have a neg 35 offset so they would be quite a way outboard. A friend fitted the same set to his 90 and they definitely stick out more than my 0 offset wheels with 285 tyres.
I have 285 75 r16s on modulars with a neg 32 offset and despite a 2 inch lift, the arches still needed trimming.
Share this post
Link to post
