pgrbff Posted January 9, 2018 Share Posted January 9, 2018 The power steering has started to play up on my hi-cap. On the one hand I thought it may be the steering column joints as it tends to be stiff, loose, stiff, loose when doing slow turns like 3-point, but on the other hand if increase the revs it tends to loosen up which I thought would indicate the pump. Any ideas? Are the pumps servicable? It can also be stiff when slowing down to turn on tight corners. If I need to replace the pump are the ZF OK? Quote Link to comment Share on other sites More sharing options...
neil110 Posted January 9, 2018 Share Posted January 9, 2018 It is possible to strip the pump and service it, though from the symptoms you describe it sounds more like one of the UJs has failed or is about to fail. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 9, 2018 Share Posted January 9, 2018 Or that there is low fluid/air in the system. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted January 9, 2018 Author Share Posted January 9, 2018 16 minutes ago, Bowie69 said: Or that there is low fluid/air in the system. Thanks, from what I'd heard I was expecting her to leak but I have never had to top her up. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted January 9, 2018 Author Share Posted January 9, 2018 Thanks Neil. The weather here has been atrocious so I haven't even had a chance to look under the bonnet. Will do as soon as rain lets up. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted January 10, 2018 Author Share Posted January 10, 2018 Does one have to remove the UJs to see if they are failing or can one normally detect movement by manipulating the steering column/UJs? Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 10, 2018 Share Posted January 10, 2018 You need to remove the lower column, but it's easy - undo the pinch bolts at each end and on the sliding joint and then slide them off the splines. Just remember to make alignment marks between UJs and the shafts. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 10, 2018 Share Posted January 10, 2018 A squirt of WD40 should tell if they are binding -it will get easier to turn immediately. If very bad you can see the movement in the UJs whilst still fitted. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted January 10, 2018 Share Posted January 10, 2018 Could also be the fan belt slipping, depending on your engine. My power steering cuts in and out on dewy mornings as I leave the drive. Quote Link to comment Share on other sites More sharing options...
