Briarston Posted January 12, 2018 Share Posted January 12, 2018 Is it really necessary for the pipework to be 1/4"? There is an adapter at the master cylinder end which must cause some restriction, and similar adapters presumably are needed to connect to the servo. The volume of fluid going in at one end is the same as comes out at the other whatever size pipe is in between surely? Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 12, 2018 Share Posted January 12, 2018 I'm guessing it allows the fluid to move faster with less friction in the larger pipe Quote Link to comment Share on other sites More sharing options...
