14Platoon Posted January 14, 2018 Share Posted January 14, 2018 I had power steering fitted to my defender 90 2.5n/a on a 1992 plate ex MOD The power steering leaks from the top of the steering box where the pipes join from the fluid reservoir. Im guessing the garage didn’t have / fit washers as I didn’t supply them and I’m guessing I need washers under the nuts on the pipes to the steering box? If this is the case, does anyone know what washers I need and where I can get them? Thanks Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 14, 2018 Share Posted January 14, 2018 No washers there that I know to , there should be O rings on the end of the pipe fittings . Did you use genuine Land rover pipes or did you have them made up ? cheers Ian Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 14, 2018 Author Share Posted January 14, 2018 2 hours ago, ianmayco68 said: No washers there that I know to , there should be O rings on the end of the pipe fittings . Did you use genuine Land rover pipes or did you have them made up ? cheers Ian I used genuine Land Rover pipes but from a spares place. I’m guessing the O rings aren’t in place but I’ll double check. Any ideas where I can get some? Thanks Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 14, 2018 Share Posted January 14, 2018 Were they brand new ? or by spares place do you mean a breakers .They're just standard rubber O rings don't know what size , what engine were they off a 200tdi ? also check they've been tightened up enough . Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 14, 2018 Author Share Posted January 14, 2018 1 hour ago, ianmayco68 said: Were they brand new ? or by spares place do you mean a breakers .They're just standard rubber O rings don't know what size , what engine were they off a 200tdi ? also check they've been tightened up enough . Spares / breaker parts. Sounds simple enough then, I’ve tweaked them tighter previously but still leaking. I’ll try to have a measure up and get some O rings for it. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 14, 2018 Author Share Posted January 14, 2018 I’m not sure what diameter o rings or thickness to get, any ideas anyone? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 14, 2018 Share Posted January 14, 2018 If they are off a 200tdi or newer (I think) the part numbers are QYX100280 AND RTC4825 but also check the pipes were they are attached to the reservoir they are held on by jubilee clips they might need tightening . also check the bleed nipple on the top of the box that might not of been tightened up properly after they bled it . Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 14, 2018 Author Share Posted January 14, 2018 1 hour ago, ianmayco68 said: If they are off a 200tdi or newer (I think) the part numbers are QYX100280 AND RTC4825 but also check the pipes were they are attached to the reservoir they are held on by jubilee clips they might need tightening . also check the bleed nipple on the top of the box that might not of been tightened up properly after they bled it . Thanks It’s a 2.5 n/a, I’m assuming The stuff came off another 2.5n/a. Already checked the jubilees and they’re good, I’ll check the bleed also though. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 14, 2018 Share Posted January 14, 2018 The part numbers from before the 200tdi are RTC4826 and RTC4825 they shouldn’t be to expensive to order the 3 . Also check the pipes they might be leaking some where. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 15, 2018 Author Share Posted January 15, 2018 19 hours ago, ianmayco68 said: The part numbers from before the 200tdi are RTC4826 and RTC4825 they shouldn’t be to expensive to order the 3 . Also check the pipes they might be leaking some where. Nice one Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 15, 2018 Author Share Posted January 15, 2018 Are the rings different sizes or both the same (I’m assuming they are the same). I can find rtc4826 if so. Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 15, 2018 Share Posted January 15, 2018 I bought a set of assorted o rings that has served me very well for my 2.5na. Make sure they are durable for oil and diesel. I’ll try find the ones I got, I’m sure there’s a brand name. Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 15, 2018 Share Posted January 15, 2018 https://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=1&keywords=Nitrile+o+ring+set&singlebutton= Im sure these were the ones. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 15, 2018 Author Share Posted January 15, 2018 55 minutes ago, DC_ said: https://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=1&keywords=Nitrile+o+ring+set&singlebutton= Im sure these were the ones. Thanks I was looking at getting a set like this. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 15, 2018 Share Posted January 15, 2018 Did you get sorted? If not , the 2 pipes are different try britcar http://www.brit-car.co.uk/ they’ve got both in stock . Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 16, 2018 Author Share Posted January 16, 2018 20 hours ago, DC_ said: https://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=1&keywords=Nitrile+o+ring+set&singlebutton= Im sure these were the ones. Ive ordered a box of O rings, hopefully I’ll get around to completing it this weekend. I’ll let you know how it goes but great help all, thanks. 1 Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 17, 2018 Share Posted January 17, 2018 Please let us know 👍🙏🏻 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 20, 2018 Author Share Posted January 20, 2018 (edited) On 15/01/2018 at 9:13 PM, DC_ said: https://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=1&keywords=Nitrile+o+ring+set&singlebutton= Im sure these were the ones. I had a closer inspection of the pipes this morning and this is what I found. The nuts are not close to the body and appear to be at a slight angle. The o rings I purchased won’t bridge that huge gap. What can I do to rectify this? Ps mental note, must check garages work in the future!!! Edited January 20, 2018 by 14Platoon Quote Link to comment Share on other sites More sharing options...
western Posted January 20, 2018 Share Posted January 20, 2018 I don't remember any 'O' rings on my PAS pipe connections, pretty sure the pipes have a domed end & matching seat in the steering box. haven't found ant 'O' ring seals listed in my 110's parts book. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 20, 2018 Author Share Posted January 20, 2018 1 minute ago, western said: I don't remember any 'O' rings on my PAS pipe connections, pretty sure the pipes have a domed end & matching seat in the steering box. haven't found ant 'O' ring seals listed in my 110's parts book. Oh ok? Wonder why these are leaking then, they seem pretty tight to be honest. Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 20, 2018 Share Posted January 20, 2018 Just went out in the -5 weather, it’s actually a beauty of a night here. Mines look like this and no leaks bud..... Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 20, 2018 Share Posted January 20, 2018 The o ring set will serve you well though in other jobs..... ask me how I know 😂😂👍 Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 20, 2018 Author Share Posted January 20, 2018 40 minutes ago, DC_ said: Just went out in the -5 weather, it’s actually a beauty of a night here. Mines look like this and no leaks bud..... Oh ok, looks about the same then. Wonder why mine’s leaking? Might try to tighten it again but don’t want to overdo it! Quote Link to comment Share on other sites More sharing options...
DC_ Posted January 20, 2018 Share Posted January 20, 2018 I wouldn’t go down the road of overtightining. Might be threaded and therefore causing the leak ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 20, 2018 Share Posted January 20, 2018 3 hours ago, 14Platoon said: I had a closer inspection of the pipes this morning and this is what I found. The nuts are not close to the body and appear to be at a slight angle. The o rings I purchased won’t bridge that huge gap. What can I do to rectify this? Ps mental note, must check garages work in the future!!! That's why most people do it themselves. It's certainly why I do. Mo 1 Quote Link to comment Share on other sites More sharing options...
