Fox Four Posted January 15, 2018 Share Posted January 15, 2018 Good evening everyone, I'm new to the world of the Defender having purchased my first one on Sunday. I know the heaters in these things are renowned for being woeful, however my heater control lever is jammed solid, with no movement whatsoever available. Has anyone encountered this before, and have any tips on how to free it? Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2018 Share Posted January 15, 2018 (edited) Which lever? Or do you mean all three? And, actually the TD5 era heaters are pretty good. No worse than any other car. Edited January 15, 2018 by Red90 Quote Link to comment Share on other sites More sharing options...
Fox Four Posted January 15, 2018 Author Share Posted January 15, 2018 (edited) Hi Red, its just the temperature control which is jammed solid, I've only got 2 heater levers. Although it appears to be jammed on full heat, it doesn't seem to be kicking out much heat at all. Edited January 15, 2018 by Fox Four Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2018 Share Posted January 15, 2018 (edited) Okay. Have a look under the bonnet and locate the heater box on the passenger side. On the top of the box, you should see a cable connected to a lever. Check and see if it is connected or if there is any reason is might be jammed. The hot position should have the cable pushing as far as possible. Cold is pulling. If that looks okay, loosen the clamp on the cable and see if the lever will move now. If it is the cable that is stuck, I would get a new cable. They are very cheap new. If you change the cable, plan to lubricate the lever mechanism at the same time. There should be two levers on the outside. One for heat control and one for the demist vents. On the inside should be a single lever for the fan speed. If anything looks strange, take a photo and post it up. Edited January 15, 2018 by Red90 Quote Link to comment Share on other sites More sharing options...
Fox Four Posted January 15, 2018 Author Share Posted January 15, 2018 Many thanks for the advice Red, I'll have a look at that tomorrow. Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2018 Share Posted January 15, 2018 read my post titled 'feeling cold in your truck, Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 16, 2018 Share Posted January 16, 2018 Hi I've been doing some heater repairs myself. The levers at the dash can stick you will need to dismantle some of the dash and see if anything is out of place. As Red90 had said check the cables on th heater box it's self. Western's write up will help you also. I dismantled a heater box the heat does not actually get turned off, the heat is deflected by flaps working via the cables. Quote Link to comment Share on other sites More sharing options...
Fox Four Posted January 16, 2018 Author Share Posted January 16, 2018 Chaps had a look under the bonnet today, the control on the top of the heater box looks quite badly corroded. I’ve given it a good blast with WD40 in the hope it might free it off. Quote Link to comment Share on other sites More sharing options...
Fox Four Posted January 17, 2018 Author Share Posted January 17, 2018 Many thanks everyone, you obvs know your stuff! Disconnected the cable from the lever on the control box, worked the flap with WD40 and that was sorted. Then removed heater controls themselves to realise they had seized. Worked those with WD40 until they freed, now toasty warm. Thank you for all your help. Never owned one before so still on the learning curve. 1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 17, 2018 Share Posted January 17, 2018 Good work. Let’s see a pic of the new motor then Quote Link to comment Share on other sites More sharing options...
Fox Four Posted January 17, 2018 Author Share Posted January 17, 2018 Here she is. 1 Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2018 Share Posted January 17, 2018 Glad your toasty warm, nice colour & looks very tidy. Quote Link to comment Share on other sites More sharing options...
Dave82 Posted February 28, 2020 Share Posted February 28, 2020 I was googling to solve this very problem and what should I find but the previous owner of my Landie asking about this problem. Quote Link to comment Share on other sites More sharing options...
Glue Posted February 28, 2020 Share Posted February 28, 2020 Spooky Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 29, 2020 Share Posted February 29, 2020 After freeing up with WD-40, what needs to happen is that you put a lubricant onto everything that will stay. The WD-40 evaporates and then you get back to the same problem. Quote Link to comment Share on other sites More sharing options...
