Land required for autobox testing
steve200TDi
Hi,
I need to get to the bottom of my autobox problems on my Comp Safari Racer which you may have been following here:
I would like to use a bit of land, be it a field or tarmac surface etc to test out my auto box in a straight line (to reduce the churning of the field, if any).
The testing would be used to determine why my box isn't shifting where it should and if I need to replace it!
I may come back again to test the improvements.
If anyone does have or know of a suitable location in the Sussex area, then please get in contact with me on here or my DM
The build thread should outline the problems I have had with the kick down cable, but basically I have adjusted it to the max and its not kicking down and changing gear above 3000rpm.
Regards
Steve
