Gazzar Posted June 26, 2018 Share Posted June 26, 2018 2 hours ago, Snagger said: If those front cylinders leak fluid out, they'll leak air in. I think we can all guess the source of those bad new parts if they leaked immediately... Rhymes with grit part? Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted June 26, 2018 Share Posted June 26, 2018 The only time I've experienced this is when the shoe springs were incorrectly fitted. As was said earlier the trailing shoe has no spring at the top. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 28, 2018 Author Share Posted June 28, 2018 Thanks Steve - Mark is going to pop round one evening next week. If we I still stumped I will give you a call. On 26/06/2018 at 4:49 PM, Snagger said: If those front cylinders leak fluid out, they'll leak air in. I think we can all guess the source of those bad new parts if they leaked immediately... I don't know what make as they were fitted prior to my mates ownership. The have been replaced with a different brand! Quote Link to comment Share on other sites More sharing options...
JCumming Posted December 17, 2023 Share Posted December 17, 2023 On 6/26/2018 at 3:59 PM, L19MUD said: This is just sat still in the workshop. We are at the happily pay someone to come and sort it now! Located near Ipswich Hi, did you find a solution to this? I am in the same situation. After 3 pumps the brakes engage, if I adjust the master the brake hold on causing them the over heat - there seems to be no middle ground for me! Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 17, 2023 Author Share Posted December 17, 2023 55 minutes ago, JCumming said: Hi, did you find a solution to this? I am in the same situation. After 3 pumps the brakes engage, if I adjust the master the brake hold on causing them the over heat - there seems to be no middle ground for me! I thought I posted the solution to this. The previous owner had incorrectly fitted springs to the bottom as well as the top meaning the shoes were getting pulled back in too far. Very easy fix in the end! Quote Link to comment Share on other sites More sharing options...
JCumming Posted December 17, 2023 Share Posted December 17, 2023 10 minutes ago, L19MUD said: I thought I posted the solution to this. The previous owner had incorrectly fitted springs to the bottom as well as the top meaning the shoes were getting pulled back in too far. Very easy fix in the end! Ah that’s good to hear! Thank you! Sadly don’t think this is my issue so I will have to keep trying to work it out Quote Link to comment Share on other sites More sharing options...
steve b Posted December 17, 2023 Share Posted December 17, 2023 3 hours ago, JCumming said: Ah that’s good to hear! Thank you! Sadly don’t think this is my issue so I will have to keep trying to work it out What do you have- 88 or 109? Any mods to the set up? Steve Quote Link to comment Share on other sites More sharing options...
deep Posted December 17, 2023 Share Posted December 17, 2023 4 hours ago, L19MUD said: I thought I posted the solution to this. The previous owner had incorrectly fitted springs to the bottom as well as the top meaning the shoes were getting pulled back in too far. Very easy fix in the end! That doesn't sound right! There should be springs top and bottom and it's the adjusters that stop the shoes going back too far. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 18, 2023 Author Share Posted December 18, 2023 13 hours ago, deep said: That doesn't sound right! There should be springs top and bottom and it's the adjusters that stop the shoes going back too far. You are right....this post is correct below On 6/26/2018 at 7:07 PM, Paul Woodward said: The only time I've experienced this is when the shoe springs were incorrectly fitted. As was said earlier the trailing shoe has no spring at the top. Quote Link to comment Share on other sites More sharing options...
