Gazzar Posted January 20, 2018 Share Posted January 20, 2018 I am restoring a lightweight at the moment, and the plan is to put MS as the engine management system on the 2.5 petrol engine I have put aside. But, it now transpires that the Lightweight was a winterised FFR, which means 24v electrics. I can still go civvy spec, but the 24v thing does appeal, god know why. Apparently one can obtain voltage droppers, 13.8v, but would they be good enough to run a MS install? Clean enough power when it's needed? Sufficient to fire the sparky thing? Thanks, G. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 8, 2018 Share Posted March 8, 2018 The MS ECU draws very little power (less than an amp), the high-current stuff is the fuel injectors and EFI fuel pump, plus lambda sensor heater. The ignition system, whatever that may be, would also draw a fair bit if it's running from the dropper. I'm not sure how much current that lot draws in total or how well it'd all run from a dropper. Quote Link to comment Share on other sites More sharing options...
