Simon_CSK Posted January 24, 2018 Share Posted January 24, 2018 I have a problem with my gear selection seems to go into 3 4 and 5 ok but finding 1 and 2 seems difficult. It feels like the sift selection has a fault like it will not go over far enough. Any ideas? Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted January 25, 2018 Share Posted January 25, 2018 That sounds like the plastic bush at the bottom of the gear lever is breaking up. Quite cheap to replace, but you've got to remove the centre console & drill out the rivets holding the tunnel plate. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted January 25, 2018 Share Posted January 25, 2018 Could that also lead to an irritating buzz on the gearstick? My D2 has a very noticeable buzz on the stick that only goes away with a hand on the stick, which leads to all sorts of other issues around safety. I replaced the engne mounts which were very sagged and it made a slight improvement, but it's still there. Quote Link to comment Share on other sites More sharing options...
bear Posted January 25, 2018 Share Posted January 25, 2018 1 hour ago, JohnnoK said: Could that also lead to an irritating buzz on the gearstick? My D2 has a very noticeable buzz on the stick that only goes away with a hand on the stick, which leads to all sorts of other issues around safety. I replaced the engne mounts which were very sagged and it made a slight improvement, but it's still there. Could be the gear box mounts as well Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted January 25, 2018 Author Share Posted January 25, 2018 21 hours ago, Pawl12 said: That sounds like the plastic bush at the bottom of the gear lever is breaking up. Quite cheap to replace, but you've got to remove the centre console & drill out the rivets holding the tunnel plate. £6.20 plus Vat for the part so that is my project for Sunday.. For that price it is worth a try, Quote Link to comment Share on other sites More sharing options...
bear Posted January 26, 2018 Share Posted January 26, 2018 In order to do that job you'll see if the bias plate is ok too. If it was me I'd rplace it as a matter of course. Part no.6 here http://www.allbrit.de/UNI.cfm?PAGE=817378&SPRACHE=EN Griff Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted January 28, 2018 Author Share Posted January 28, 2018 I replaced the plastic bush and checked the bias plate wasn't broken but still no joy. I did fix the hand brake so not a completely wasted day lol I am guessing therefore it must be something deeper in the gearbox. As long as the car keeps going until I can fix my other Disco and my P38 I will be happy. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted January 31, 2018 Share Posted January 31, 2018 On 25/01/2018 at 2:07 AM, Pawl12 said: That sounds like the plastic bush at the bottom of the gear lever is breaking up. Quite cheap to replace, but you've got to remove the centre console & drill out the rivets holding the tunnel plate. Mmm, and then I could fit the D1 Low/High/Diff Lock lever I scrounged. Good plan. Quote Link to comment Share on other sites More sharing options...
finnarne Posted January 31, 2018 Share Posted January 31, 2018 On 25.1.2018 at 2:43 PM, JohnnoK said: Could that also lead to an irritating buzz on the gearstick? My D2 has a very noticeable buzz on the stick that only goes away with a hand on the stick, which leads to all sorts of other issues around safety. I replaced the engne mounts which were very sagged and it made a slight improvement, but it's still there. Check that the bolt locking the upper part of the gear stick is tightened. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted February 1, 2018 Share Posted February 1, 2018 Is that number 13 on the diagram posted in bear's link? Quote Link to comment Share on other sites More sharing options...
finnarne Posted February 1, 2018 Share Posted February 1, 2018 Yes, number 13. When I changed the gearbox in my D2 (auto -> R380), I had an annoying sound that went away when I had a hand on the gearstick. It also helped to tightened that bolt. Quote Link to comment Share on other sites More sharing options...
