Naks
Groaning noise on Ashcroft ATB
3 minutes ago, Bowie69 said:
Yup, ring and pinion is likely scrap now, they have just changed when the noise happens.
I'd probably send the ATB centre back to Ashcrofts for a checkover, and get their opinion on it. I appreciate that may not be an option for you....
Drive it with rear prop removed, and in diff lock, you will isolate the transfer box, front drivetrain from the problem that way, it should change/go quieter/silent.
If sending it back to the UK.... get it sent on to Nigel at Xcess4x4. He'll build it into a diff properly.
Share this post
Link to post
unfortunately sending it back to the UK is not really an option.
I will take it to the chap who imports them, he probably has more experience with working with diffs
Share this post
Link to post
Find a new shop to work on it.  Time to just take a loss on a place that is incompetent.
Share this post
Link to post
TIA...
Share this post
Link to post
I've just had a pre-owned Ashcroft ATB fitted to the rear axle of my RR P38 4.6... it was a whole, built diff unit, from another vehicle, not a core. Will it need any lash/runout adjustment because it's in a new home?
Share this post
Link to post
Not normally, no, should be fine, as you set them up on the bench anyways, unlike a Salisbury axle :)
  • Like 1
Share this post
Link to post
Good to know, thank you.
Share this post
Link to post
On 2/14/2018 at 11:15 AM, Hybrid_From_Hell said:
Quote
Just got an update from the workshop: they fitted a new crownwheel + pinion and the problem is gone, plus one of the bearings was not sitting properly (not too sure about the exact terms).
the original diff was replaced by LR after about a year of ownership, so not sure if that was not done properly, and after 9 years it finally went over when the ATB was installed?
my indie says now that the droning noise from the diff is gone, there's a 'squeaky' noise that's appeared, and he thinks there's a bearing in the gearbox that needs inspecting  :rolleyes:
In which case he needs kicking in the crown jewels for being a Knob :D
I refer the honourable gentleman to my earlier comment :D
Share this post
Link to post
Finally got the landy back after it spent 7 months in the shop.
During a  very thorough investigation into the root cause of the vibrations, the following were replaced:
- rear propshaft
- A-frame ball joint
- rear springs (Terrafirma Heavy)
- all bushes
The landy now drives much better, although there's still a vibration at low speeds coming from the gearbox/transfer case area (bum area) and the rear diff howls at around 80kmh.
Having been without an off-roadworthy landy since Feb 2018, I'm done trying to sort this out any further.
I guess this is a Defender after all, so I shouldn't complain that it isn't safe, comfortable, etc., and just live with the issues.   🙄
Share this post
Link to post
