dave88sw Posted February 6, 2018 Share Posted February 6, 2018 Hi, I've been given a 19J Defender to sort out for somebody. I was told it had started playing up and eventually refused to start at all, i checked everything fuel wise, had decent fuel supply to the injection pump and the solenoid definitely opened but nothing made it to the injectors. So i've changed the pump for a second hand unit and i'm at the point where i need to put the timing belt on. Now, i know where all the marks are on the relevant pulleys, that's easy enough to line up but i've never actually done a 19J belt before (loads of tdi's), the pump is mounted on slots, which suggests it's adjustable on these slots to advance/retard. Is there any way to lock the pump in the right position, like the TDI, or do i adjust the final position of the pump afterwards until it runs right? I have searched endlessly online and despite threads being titled 19J, the advice appears to relate to TDI's, there is no hole in the front of the pump for a timing pin. Thanks Dave Quote Link to comment Share on other sites More sharing options...
monkie Posted February 6, 2018 Share Posted February 6, 2018 If you get this tool set it has a springloaded pin that screws into the side of the FIP and clicks into place when the pump is set at the right point for timing the engine (it also contains a locking pin for the crank and also a puller for the crank damper). https://www.ebay.co.uk/itm/Land-Rover-Diesel-Engine-Timing-Garage-Tool-Set-Kit-200-TDI-300-TDI-2-5D-2-5TD/141027669413?epid=1005459073&hash=item20d5e775a5:g:uGQAAOxy3HJTI2gR The picture below shows the screw taken out of the pump and the timing pin inserted in its place. Quote Link to comment Share on other sites More sharing options...
zeerover Posted February 10, 2018 Share Posted February 10, 2018 You don't need a tool, a torch and eye will do. Beter a little to soon than to late. Quote Link to comment Share on other sites More sharing options...
