Happyoldgit Posted February 26, 2018 Share Posted February 26, 2018 Did it loose any oil this time? Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted February 26, 2018 Author Share Posted February 26, 2018 Yes, nice trail of it down the road. Looks to be coming out of the oil filter seal again. I parked it up and shut the engine off quickly so not to starve the big ends etc... Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 28, 2018 Author Share Posted March 28, 2018 After the car sitting on the road outside the garage I took it to, and them doing sweet FA despite multiple failed promises, I decided enough was enough, screeched into the forecourt in my Land Rover, parked on the boss man's toes and demanded the keys back, which he duly handed over and walked away without a word. That evening I went back to see what state it was in. As expected battery flatter than 3 week old road kill, and the oil filter O-ring hanging out again. After a big sigh, I sorted those out, chucked some more oil in and drove it the half a mile home. This evening I made some time to get it in the garage and up on some ramps. 20 minutes later, and out pops the PRV. Can you see the problem...? Quote Link to comment Share on other sites More sharing options...
qwakers Posted March 28, 2018 Share Posted March 28, 2018 (edited) On 19/02/2018 at 8:33 PM, qwakers said: ive seen several instance of this in a mates workshop on fords, its always a stuck pressure relief valve, gunked up by too infrequent oil changes or damaged somehow. the sometimes also stick open, with obvious results... ahem Edited March 28, 2018 by qwakers Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 28, 2018 Share Posted March 28, 2018 Hmmm, 20minutes? So what took them 3 weeks? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 28, 2018 Share Posted March 28, 2018 So the PRV is accessible without dismantling the engine then? Good news. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 28, 2018 Author Share Posted March 28, 2018 It was pretty easy to get to in the end, just the air con pump to move out of the way. Hence 20 minutes. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 28, 2018 Share Posted March 28, 2018 Well I am pleased for you, but perplexed by the garage's behaviour... Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 28, 2018 Share Posted March 28, 2018 Not entirely surprised at the garage, but great result. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted March 29, 2018 Share Posted March 29, 2018 Good that you can get to the PRV and discover an issue. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted March 29, 2018 Share Posted March 29, 2018 If the spring is broken and therefore shorter wouldn't that mean it would lift earlier and so be lower pressure? Or do you think the bits were jamming it shut? Either way replace the bits and see what happens Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 29, 2018 Author Share Posted March 29, 2018 When I first took the end cap off, some of the broken rings were clearly wedged in sideways between the cap and plunger. By the time I found a magnet to retrieve them, they had fallen out of their own accord so missed the opportunity for a picture. 3 Quote Link to comment Share on other sites More sharing options...
