Myroverdontturnover Posted February 19, 2018 Share Posted February 19, 2018 Hello, I recently bought a 2000 D2, reminiscing about my d1 that left me stranded and so its really an R2D2. Any how all jokes aside, I bought it and it didn't run so I changed the starter and wired a butt ton to by pass the interrupter at the ignition switch ( the same was done on the d1, not my first rodeo) I had issues getting the trunk door open on both too and forgot what i did to get it open but by pure magic one day while trying all the tricks and trade secrets by experts in the field of car thieves (such as trying to reach the original cast and crew of gone in sixty seconds per se) drinking lots of beer and going at her again one day the land rover gods came down from the heavens and the back door opened just long enough to spray down the mold then re-locking again with all my tools and cleaning product to sit in the back to suffer separation anxiety because now I cant drive it, i cant clean it and now i cant even get in it. The drivers side window is open just enough to allow me to get a special made tool (a machete with a broken handle taped to a thin metal brace used to stabilize my metal shelving unit) so i can "tap" the center of the dashboard button and "unlock the door as if i were sitting in it, though then the battery seems dead so I easily removed the grill and cut away the plastic bezel with a rotozip opened the hood and disconnected the battery and charged it, reconnected it and used ye ole special tool and gave it the "quick tap" (my new term for my new process with my invented tool) to no avail. What to do here? Buy a couple of them online for cheap because they don't run either just for parts? Help help this rover is trying to bend me over for the dealership, help Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 20, 2018 Share Posted February 20, 2018 Won't help you if you have locked it, but back door issues are usually the flap inside the handle sticking, which you fix by taking out the Land Rover badge and pushing the flap back down again. Not 100% sure if the same trick works on a D2, it's a while since I have had to do it. If the vehicle is deadlocked then the CDL button inside won't work and neither will trying to open a door with the interior locking mechanism, because all those are isolated. Why don't you just open the door with the key, or are you going to tell me you don't have a key and/or the door lock is broken as well? Quote Link to comment Share on other sites More sharing options...
discokev Posted February 20, 2018 Share Posted February 20, 2018 If you can open the bonnet check the main feed into the fuse box ,had axact same fault with my 2003 the nut was lose. Best of luck Kev. Quote Link to comment Share on other sites More sharing options...
