evanmc Posted February 25, 2018 Share Posted February 25, 2018 1985 2.5NA 110 When I removed the head to replace the gasket, two of the pre-combustion chambers fell out onto the block. I assume these are friction fit, but will not stay in place by just re-inserting them. They are not damaged; they just won't stay in place. Should these be replaced? Held in place with somehow while I lower the head back on? Thanks, -Evan- Quote Link to comment Share on other sites More sharing options...
monkie Posted February 25, 2018 Share Posted February 25, 2018 They are held in place when the head is fitted on the block. It is more important that they do not protrude beyond the limits in the workshop manual. The suggestion offered in the workshop manual is to use a bit of grease to hold them inplace while you put the head back on. Quote Link to comment Share on other sites More sharing options...
