farkit Posted March 2, 2018 Share Posted March 2, 2018 Hi Guys, Whilst my 200 Tdi 110 is in bits, I've been considering a V8 conversion. I know there are lots of options, but would I be right in saying that the most straight forward would be to find a Disco V8 and R380 gearbox, and fit these as a unit? I know that the gear selector will need to be swapped for a Defender unit, but in theory it should be a relatively straight forward conversion? Will the bulkhead need to be modified? Any guidance or input gratefully received... Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 3, 2018 Share Posted March 3, 2018 I can't help much but I do know you will need from a 300 or td5 both floor pans, tunnel and bulkhead flange. You will need to modify or replace your seat box and engine/gearbox mounts. Mike Quote Link to comment Share on other sites More sharing options...
farkit Posted March 3, 2018 Author Share Posted March 3, 2018 That's a great help, many thanks Mike - I'll start looking out for those. Quote Link to comment Share on other sites More sharing options...
skauldy Posted March 3, 2018 Share Posted March 3, 2018 I'm in the same stage and as Mick said above I had to change to td5 parts for auto box to fit Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 3, 2018 Share Posted March 3, 2018 6 hours ago, miketomcat said: I can't help much but I do know you will need from a 300 or td5 both floor pans, tunnel and bulkhead flange. You will need to modify or replace your seat box and engine/gearbox mounts. Mike I used a disco r380 gearbox with my lt77 floor....it’s tight but fits start to finish build thread 200tdi to 3.9v8 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 4, 2018 Share Posted March 4, 2018 P38 will have the wrong/weird P38-specific clutch, so yeah Disco 2 for the 4.0 would be my vote, later Thor lumps with the bunch-of-bananas plenum gain you 20 torques at the low end but cost you minor plumbing wrinkles. I'd vote 4.6 all day long but I'm biased. Make sure you get the PAS pipe from the pump on the 4.0 / 4.6 to make your life easier. 1 Quote Link to comment Share on other sites More sharing options...
qwakers Posted March 5, 2018 Share Posted March 5, 2018 nah its gotta be a TVR 5.0 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 5, 2018 Share Posted March 5, 2018 5 hours ago, qwakers said: nah its gotta be a TVR 5.0 Built from whatever they had laying about, tuned to move a small plastic car around at high speed... the state of tune may not be ideal for a 2-ton wardrobe 2 Quote Link to comment Share on other sites More sharing options...
qwakers Posted March 6, 2018 Share Posted March 6, 2018 nahh lob a torquey cam in it and squirt it you cant lose Quote Link to comment Share on other sites More sharing options...
Ozzy50 Posted March 6, 2018 Share Posted March 6, 2018 Modify the transmission tunnel to take the disco gear stick ,you lose the middle seat but gain a nicer more positive (err a bit more positive anyway ) gear change and lose the big pudding bowl stirrer . I fitted a 200 tdi and lt77 from a disco into my 110 , used the disco handbrake as well , doesn’t take much to make it fit and look nice , James Quote Link to comment Share on other sites More sharing options...
