BigJ
6cyl SWB?
7 minutes ago, FridgeFreezer said:
Changing the bulkhead won't change where your engine + box sit, that's what engine + transmission mounts are for :P and yes it was *all* different on the 6cyl.
Sorry, I didn’t explain myself very well. I was trying to figure out if the gearbox mounts for the 4&6 cylinder models were in the same place on the chassis or if on the 6 cylinder they sat further back on the chassis hence the need for the different bulkhead. I’m assuming in this that the distance at the front for the fan, radiator, front panel etc is the same on both models. Or, is it just the position of the engine mounts that differs between them?
From what I can gather what others have done is keep the gearbox in it’s original place, change the bellhousing and fit the 6 pot by moving the original mounts forward by a few inches.
Apart from hole patterns is there any other difference in dimensions between the 4&6 pot bellhousings?
Share this post
Link to post
The gearbox is indeed mounted further back in the 109. To accommodate this, the crossmember immediately behind the hand brake drum is also further back in the chassis - about two~three inches if memory serves.
Do bear in mind that finding a six pot in decent order is pretty hard and/or expensive these days, and parts are also expensive. The humble V8 will be an easier fit in a SWB, return same or better mileage and cost far less. They also weigh a lot less! They're hefty bits of iron those old blocks, as you've already figured out.
I'm doing a six pot for a late 2A restoration, because I want to keep it as originally built - the cost is vaguely eye watering. I bought the best "running" P4 engine I could in the hope I could get away without rebuilding the seized LR engine, but for many hundreds of pounds I got a block that's worn through the coating on the bearings shells and has bores worn enough to require oversize pistons and a rebore. It runs, but it's far from healthy. Now I know what I'm looking for, I'm struggling to find better.
I understand the urge to do something different, and they're lovely old things, but I'd question it being worth the work. My 2p worth, anyway.
Share this post
Link to post
Another gearbox query if anyone can help, are the six and four cylinder boxes the same except for the bell housing and if so are the bell housings interchangeable?
Same question for the flywheel.
Share this post
Link to post
I'm in the middle of converting my ex mil 109" IIA to 3 lt Rover (Westlake head, Weber carb), keeping the factory bulkhead (mine's LHD).
The engine sounds great on stand, I'm glad to hear such positive comments about those who owned one, I hope it will perform as good as it sounds :-)
Share this post
Link to post
I didn’t realise there was a Weber conversion available, do you have any further details please?
Share this post
Link to post
Actually there isn't a conversion available, it just happened the factory carb was shot beyond repair, so I switched to a 32/36 DGV, which needed a custom billet adapter.
Here's a photo of the thing.
Share this post
Link to post
Do these help?
Share this post
Link to post
They sure do Mr Freezer, thank you very much 👍. My engine is the 3.0 out of a P4 Rover but hopefully the 2.6 bell housing, flywheel and clutch will bolt straight on. I notice the gearbox numbers are different though. Are the 4&6 cylinder boxes interchangeable or do they have different ratios?
Share this post
Link to post
At a guess the input shafts may be different lengths / diameters / splines to suit the bellhousing / clutch / flywheel / crank spigot bush. The parts book is online as a free pdf, I'll leave it to you :P
Share this post
Link to post
4 - 6 cylinder boxes.
Leaving aside the 1 tonne box the 6 cylinder has a different gear lever.
There are 2 bellhousing bolt patterns - one for ioe engines - 1.6, 2.0, amd 6 cylinder and another for OHV engines.
Then there's the larger layshaft bearings of the later S2/2a boxes
Then the S3 clutch cylinders - avaiable for both types of bellhousing.
Share this post
Link to post
Cheers for the info. I’m hoping to retain a full synchro box but it sounds like I need to source a complete S3 6 cylinder box rather than just bolt a 6 cylinder bell housing to my existing 2.25 box which I thought I could do originally.
Share this post
Link to post
The engine mounts on the six cylinder engine seem to be about 6” further forward of those on the four cylinder block. Is the depth of the six cylinder bell housing the same as the four cylinder one in which case would it just be a matter of moving the existing mounts 6” further toward the front of the chassis?
If so then that would put the new engine mount where that bracing is to the left of the bolt. 🤨 If the six cylinder bell housing was not as deep as the four cylinder one then that would help as there’s still a bit of room at the back of the engine bay for the six cylinder to sit closer to the bulkhead.
Share this post
Link to post
I’ll reply to your PM in a bit, but I did take a couple of quick photos for you!
Share this post
Link to post
Cheers Jeremy. Those photos make things much clearer. If you didn’t use the mechanical fan do you think you might avoid the need to remove some of the radiator surround? Does the crank pulley or sump come close to any fixtures or the crossmember?
Share this post
Link to post
This is the engine I have planned for the conversion. It’s out of a 1965 P5 auto and more or less complete but will require a full strip down and rebuild. Torque converter needs to come off and the dyno replaced with an alternator. Convert the dizzy to points free operation and hopefully the angle of the exhaust manifold should allow a relatively easy adaptation to the existing down pipe.
Share this post
Link to post
Some more photos, still experimenting with posting pictures 🙄 Not sure how to resize them to make them fit the screen. First two were attached direct from my iPad. These are done via post image.
08784_DE9-4065-4860-_B392-_CF3_D5_B1_ABA
4_B7_D8248-2963-4_CF5-9_EE4-9218_FA4_C04
66080_C3_D-_DE62-4_C23-899_E-5_A3_BA231_
8_F9_BCBBF-_A811-4776-825_E-_B41_C19_DF2
E1637_B52-822_B-487_B-885_F-7336620_EA40
Edited by Bigj66
Share this post
Link to post
1 hour ago, Jeremy1 said:
Looks nice! I’ve just bought another engine, 3.0 Weslake. No plans for it yet!
I believe that’s what this one is, the 130bhp version. Not sure what the wooden handle is on top of the rocker cover? Maybe for the jack?
Share this post
Link to post
Noise deadening sound bar :D
Engine should sound great in your landy :D
Share this post
Link to post
I’m in the middle of building a workshop to house the rebuild of the 88 along with the engine conversion. Once I’m up and running I’ll start a proper build thread as I think I’m going to need a chuck up with this one.
Ideal world would have been fitting this engine into a ‘66 LWB but I don’t have one so the 88 will have to do.
Share this post
Link to post
The search is on for a bell housing to do the conversion. Have I understood it right that the Series 2a & Series 3 6 pot bell housings are the same as the 2.0 Series 1s? Might make the search a bit easier if they are...
If anyone knows of any bell housings, flywheels or other 6 cylinder parts for sale a PM would be appreciated.
One other question. The donor engine for mine came off an auto P5. I know I will need to remove the torque converter etc but does anyone know if the flywheel housing is still the same as the Landrover one? There’s a picture of it earlier in the thread.
Share this post
Link to post
If we weren't so darn far apart I have a 6 cyl LR shortblock with flywhell clutch etc you could have for free! It has thrown a rod so not worth much, next stop the scrappy!
Share this post
Link to post
Forum Relay ?
Share this post
Link to post
1 hour ago, Arjan said:
Forum Relay ?
No need Arjan, I’m in DK several times a month so calling in to see Soren won’t be a problem as he’s quite close to where I work.
Carrying a flywheel in my suitcase though....💪
Share this post
Link to post
I'm pretty sure a lot of stuff is compatible with the 4 cyl IOE such as oil pump rods and pistons , exhaust rockers then all the external stuff on the front and back too so maybe worth stripping the common stuff to sell/pass on ?
I may have what you need bigj66 , I'm going to be in my Series 1 storage at the weekend looking for an early 4 cyl dizzy for someone so will check
cheers
Steve b
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
