bnamunds Posted March 7, 2018 Share Posted March 7, 2018 All, I'm replacing my old D90 body onto a new richards galv chassis, YRM patched seat pan, YRM patched footwells, and new welded in YRM bulkhead A-pillars. I've got everything roughly placed in with all bolts still loose so I can adjust. I'll be using the string method to align the curves of the rear tub to the curves on the bulkhead. What I need is the correct measurement for the door opening from rear tub to the bulkhead. Essentially what I'm looking for is the proper measurement for the door opening (door width plus gaps on both sides). Right now I have one side at 87.6cm (34.5") and one side at 89.1cm (35.1"). I can adjust either side, or both, but I don't know what measurement to use. I also do not have the doors to measure (I'm ordering new ones and don't have them yet) which is why I'm asking. Thanks fellas! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 7, 2018 Share Posted March 7, 2018 I would wait until you have your doors and measure them, especially if using non-genuine ones. 1 Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted March 7, 2018 Share Posted March 7, 2018 Doesn't give you a door dimension, 890mm rings a bell though... Edit: Just had a look back at my rebuild and for the doors it was 880mm with a 7mm gap all round on mine. This was with original door frames wrapped in SPL replacement aluminium skins. You can assemble loosely but don't tighten everything up until they are all together, having a bit of a wiggle helps to line up all the panels before tweaking the gaps to suit Quote Link to comment Share on other sites More sharing options...
steve b Posted March 7, 2018 Share Posted March 7, 2018 That sounds right Scott , I've recently been re-aligning a badly built Series 2a and the doors are 864 to 865mm(34") wide - all the way through the range including Defender . cheers Steve b Quote Link to comment Share on other sites More sharing options...
