Sign in to follow this
Cornish Rattler
Part number's please
I’ve fitted a 300tdi one to suit the manifold ...
Share this post
Link to post
Thought that was a push in fit mines a screw in fit
Share this post
Link to post
I’ve transferred the screw and olive bit over to the 300 tube. The tube fits in just the same and the length seem the same - so my plan was to benefit from the better fit and double check the reading by pouring in a precise amount of oil.
Share this post
Link to post
Are right ok i will need to get the screw in and olive part then
Share this post
Link to post
I think I ordered the olive and tube - but re-used the screw in bit. Do you not have the original dipstick with it ?
Share this post
Link to post
I did also consider using the series set up from the 2.25 - which I think is the same part as used on the 200tdi Defender engine - but I wasn’t sure how it would fit with the manifold.
There is a cheap one on eBay: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F253413495722
Looks like it should probably fit as it’s shorter and self supporting ..
Share this post
Link to post
Share this post
Link to post
Yeah it is very tight and i think it would break before it bends enough i've got the Def 200 one to try and its to tight
Share this post
Link to post
I will check it tomoz as i only finished work a 10:00 pm
Share this post
Link to post
Share this post
Link to post
Yes i still have the original one but its a 200 Def one as originally the engine was a Def engine but re-dressed as a Disco engine ( damaged timing case ) with a 300 turbo / manifold now fitted.
Would you happen to have the part number for the olive so i can buy one :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
