FridgeFreezer Posted March 14, 2018 Share Posted March 14, 2018 I recently picked up an air filter housing which i thought was a 200TDi Defender one (round metal can type), however it has a wider mouth and the standard filters (60666?) don't fit into it as the hole in the end is too small. So, what have I got & what fits in it? Quote Link to comment Share on other sites More sharing options...
western Posted March 14, 2018 Share Posted March 14, 2018 got a photo of it ? only other know of with similar is the 300tdi air cleaner for defender but pretty sure the can is a bit longer Quote Link to comment Share on other sites More sharing options...
Escape Posted March 15, 2018 Share Posted March 15, 2018 You sure it's LR? I have a small loader with a similar-but-not-quite-identical filter housing. Would have been to easy if I could just throw in a cheap LR filter, instead of trying to track down an original... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 15, 2018 Share Posted March 15, 2018 2.5D filter? IIRC they were smaller? I wish LR did what VW/Audi did and put part numbers on EVERYTHING.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 19, 2018 Author Share Posted March 19, 2018 It says ESR2102 I think. It's not a 2.5TD as those are shorter, this one looks almost identical to 200TDi Defender but the mouth is bigger. Edit: I'm totally confused about filters now... The 109 has (what I think is) a std. 200TDi Defender can which takes standard filters (NTC6660) The Ambulance has (what I thought was) the same filter can, but the outlet turned out to be smaller (something like 2" diameter instead of 2.5" - 3" ish) and there was a secondary smaller filter down the inside. It does accept NTC6660 filters though. The can I have NOW got (ESR2102) I thought was the same but with a bigger outlet, but it won't accept an NTC6660 as the support up the middle is too wide where it joins the wider outlet, the mouth of the NTC6660 fouls on it and is visibly smaller diameter than the can's outlet. My brain hurts. Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 19, 2018 Share Posted March 19, 2018 ESR2102 is a 300TDi filter housing according to Google. Filter should be ESR2623M. Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2018 Share Posted March 19, 2018 as above esr2102 = 300tdi air cleaner https://www.brit-car.co.uk/product.php/101405/5497/air_cleaner_assy_300tdi_disc_def Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 19, 2018 Author Share Posted March 19, 2018 Cheers guys, as I said it threw me totally that it looks identical to the 200 one but wouldn't accept the filter! Quote Link to comment Share on other sites More sharing options...
muddy Posted March 19, 2018 Share Posted March 19, 2018 The 300 needs the bigger filter for the extra 100HP the ambulance one sounds rather military ( to be expected I suppose!) with the inner filter I've never seen or heard of that on a landrover. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 20, 2018 Author Share Posted March 20, 2018 The inner filter took me by surprise too, and it wasn't sold as anything special, just a random item of junk from a fairly disinterested seller at Sodbury. The inner filter slides down the middle of the NTC6660, it has (IIRC) a UPI part code on it and is more fluffy fabric than pleated paper. Quote Link to comment Share on other sites More sharing options...
