mad_pete Posted March 17, 2018 Share Posted March 17, 2018 Seems the person I bought my bulkhead from had the idea removal of the bulkhead strap was faster with a grinder. So the metal bar here where it attaches to the bulkhead has been ground off on mine. Is it important ? Should I try and weld something back on ? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 17, 2018 Share Posted March 17, 2018 Personally I would say yes as there is only the 2 bolts holding it were it attaches to the footwell and I would imagine in time with the stress of turning the steering wheel frequently you would eventually damage the footwell possibly even tear it loose as it would act as a pivot point when turning . cheers Ian Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 17, 2018 Author Share Posted March 17, 2018 Where do you think I could get one ? Do they come as a separate item ? Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 17, 2018 Share Posted March 17, 2018 Yes definately needed, I had to make one for my series when I fitted PAS as without the column vibrated badly. would only take a couple of minutes to make something and weld it on. It can be pretty agricultural as it’s an area that never gets seen..... Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 17, 2018 Share Posted March 17, 2018 I can measure the one on the bulkhead off my project tomorrow for you if you’d like ? But as said above I’d just make one . Quote Link to comment Share on other sites More sharing options...
AV8R Posted March 17, 2018 Share Posted March 17, 2018 The brackets are welded to the bulkhead and not available as a seperate item. Last year I had to make one as well. Seems there are more people thinking you can do without them. Not me though, it adds a lot of rigidity to the steering column. It is a bit of an awkward thingy to make as there are a few bends next to each other to match the contours of the bulkhead just above the vent opening. I ended up with bending two pieces sheetmetal with 90 ° bends, cut them to the proper dimensions and TIG weld them together so it would look like a factory bracket. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 17, 2018 Author Share Posted March 17, 2018 If you could measure that would be great please. Learning to weld and get a welder is on my todo list but I’ll try and work something out. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 17, 2018 Share Posted March 17, 2018 No problem Pete will take you a photo as well . 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 18, 2018 Share Posted March 18, 2018 Hi Pete it’s 40mm long with a 10mm hole and the hole center is 30mm from bulkhead , here’s a couple of pics for you as well. have you got the strap that goes from the steering column to the bracket? cheers Ian 1 Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 18, 2018 Author Share Posted March 18, 2018 Thank you for measuring and the pictures . I think I do have the strap around somewhere. I’ll check my boxes of bits. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 18, 2018 Share Posted March 18, 2018 No problem mate . Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 18, 2018 Author Share Posted March 18, 2018 So parts box did turn up the brace. is it just a question of welding a bit on the end or would it need extra support ? Quote Link to comment Share on other sites More sharing options...
AV8R Posted March 18, 2018 Share Posted March 18, 2018 The rest seems to be still on the bulkhead. Just weld that bit on and make it look like the tab in Ian's photo. Quote Link to comment Share on other sites More sharing options...
Daan Posted March 18, 2018 Share Posted March 18, 2018 I don't have one. Daan Quote Link to comment Share on other sites More sharing options...
mad_pete Posted August 13, 2018 Author Share Posted August 13, 2018 Got an arc welder and had a go but it was tricky to line up the weld line so tried Mig and I think it’s on. Second ever weld for me for both types. Apperantly practising is a thing but I’ll work on that later. :-). This is the arc. This is the mig with some grinding. It’s a little awkward to grind so it’s not totally flat. just like in the picture (sort of). but it’s on and I think that will do. 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 13, 2018 Share Posted August 13, 2018 Looks fine Pete . Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 14, 2018 Share Posted August 14, 2018 I just repaired mine last week. It corroded away and one day went PING when I pulled myself into the van using the steering wheel, after which it squeaked like a bugger when in low revs. I was able to drill a hole through the back of the bracket (on the U) and bolt it to the repair section I usd to patch the bulkhead with an M14 bolt. Worked just fine, now squeak-free and solid. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted September 2, 2018 Author Share Posted September 2, 2018 Not quite a factory finish and the camera is a little unkind in its ability to highlight the imperfections but call that job done. Quote Link to comment Share on other sites More sharing options...
