Stellaghost Posted August 15, 2023 Author Share Posted August 15, 2023 4 hours ago, Wytze said: Not much... Just a 1000 pound flange made😁😁 Ha I wish, slightly more involved than just that bit, that's probably only about £300's worth of the equation.......lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 15, 2023 Author Share Posted August 15, 2023 4 hours ago, Stellaghost said: Not a lot done today as on nightshift Managed to cut out 1uz flange Regards Stephen I Hasten to add the above is initial baby steps, will need some more trimming to allow flywheel to fit, just holding back a bit until I have section cut off gearbox side to see how things go/mate up regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 16, 2023 Author Share Posted August 16, 2023 Engine flange completed ready for tig From yesterday today flywheel fitted nice clearance all round regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 16, 2023 Author Share Posted August 16, 2023 Need to rig up a slitting saw on mill to cut next section for gearbox side Also the below has possibilities for joining the two Flanges together One alloy wheel rim Fits around flywheel nicely so there is possibilities with this, just need to cut things down and see how its goint to work to make a complete adaptor regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 16, 2023 Share Posted August 16, 2023 To clarify, are you cutting the LT77 bellhousing down or something else? As usual you have things done before I can think about leaving my day job alone. Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 16, 2023 Author Popular Post Share Posted August 16, 2023 1 minute ago, Bowie69 said: To clarify, are you cutting the LT77 bellhousing down or something else? No I'm cutting the aluminium casting down on the end of the 200tdi engine that fits around the Landrover fly wheel, this gives me the lt77 mounting points, this is what needs joining into the 1uz flange I've made, I need to make up a 35mm gap, but may stretch that to 40mm if it gives me a bit more wiggle room Also looking to make threaded studs for the 1uz side as it may give me more room putting a bit on as allows to trying to get a bolt in Hopefully that makes sense as I've still got tired nightshift head on, although last one tonight Regards Stephen 4 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 16, 2023 Share Posted August 16, 2023 Yup it does, thanks Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 18, 2023 Author Share Posted August 18, 2023 So got my Bridgeport running this morning, still need to suss a few things out, but I need it for a wee bit of Heath Robinson fun So one drill attachment in the lathe with a disc grinder nut on it to turn down disc locating section why? because i needed to fit a circular saw blade onto it insert into chuck on mill and bolt casting to cut onto bed Start cutting, this is not where final cut will be, just seeing if it will work and no damage sustained by myself ...lol 20230818_144714.mp4 Appears to be OK will just need to go slow and steady could have done it on my other mill but the Bridgeport has a way bigger bed and range of compound slide movement so i should be able to set it up to do all in one position, could not do that in my other mill without repositioning regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 18, 2023 Share Posted August 18, 2023 Where there's a will there's a Stephen. 🫣 I love this. Mike 1 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 18, 2023 Author Popular Post Share Posted August 18, 2023 Well all I can say is it works Tried it on an alloy wheel first as I have 4 of them regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 18, 2023 Share Posted August 18, 2023 Please say you are at least wearing a leather apron, or..... Something to stop the really sharp whizzy thing should it come loose... I would prefer there to be a Stephen for next 7S.... 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 18, 2023 Author Share Posted August 18, 2023 2 minutes ago, Bowie69 said: Please say you are at least wearing a leather apron, or..... Something to stop the really sharp whizzy thing should it come loose... I would prefer there to be a Stephen for next 7S.... How sweet....... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 18, 2023 Share Posted August 18, 2023 12 minutes ago, Bowie69 said: I would prefer there to be a Stephen for next 7S.... Better than having two of him 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 18, 2023 Author Share Posted August 18, 2023 39 minutes ago, Ed Poore said: Better than having two of him If there was two of me I would get twice the amount of work done.... Regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 18, 2023 Share Posted August 18, 2023 1 hour ago, Stellaghost said: If there was two of me I would get twice the amount of work done.... Regards Stephen We can't keep up with you as is! [edit]Although if there were two of you maybe one of you could tour the country to help us folk struggling for time with our projects [/edit] 2 Quote Link to comment Share on other sites More sharing options...
ped Posted August 18, 2023 Share Posted August 18, 2023 that's one way of doing it i use a slitting saw and arbor now and again as i mostly need a thinner kerf cut did you do it in one go or leave a few holding bits to stop it flapping about and trapping th blade Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 18, 2023 Author Share Posted August 18, 2023 19 minutes ago, ped said: that's one way of doing it i use a slitting saw and arbor now and again as i mostly need a thinner kerf cut did you do it in one go or leave a few holding bits to stop it flapping about and trapping th blade One go Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 18, 2023 Share Posted August 18, 2023 When using a slitting saw on something likely to vibrate and be a pain I used to use a couple of techniques. If it was something like slitting the side of a tube, I used to shove a blue tack like material we use for vacuum leak checking inside to stop it moving about. For things that could be clamped, I’d use a slip gauge in the gap the blade is creating and clamp that up to take out the vibration. The latter also means if you do it in a few places you can keep the workpiece solid. 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 18, 2023 Share Posted August 18, 2023 He'll have already done it by now... 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 19, 2023 Author Popular Post Share Posted August 19, 2023 So cutting of adaptor parts this morning (sorry to disappoint you @Ed Poore ) Voilà Sort of mounted together will be some issues with bolts but I figure I can mill down through bolt holes then enlarge to take Allen bolt head ( smaller than using conventional bolts probably need to clean things up, dig out spool gun, mate box to engine with loose bits in-between and tack together, pretty sure it will not go as smooth as talking it Regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 19, 2023 Share Posted August 19, 2023 Impressive. Let it soak in degreaser for a good while before you attempt to weld that? 1 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 19, 2023 Share Posted August 19, 2023 4 hours ago, Stellaghost said: mate box to engine with loose bits in-between and tack together, pretty sure it will not go as smooth as talking it Can you make up a jig (even timber) to hold the engine and gearbox in the right locations then you can tweak and align things before tacking them all in place. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 19, 2023 Share Posted August 19, 2023 Filling the gap up with welding wire? Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted August 19, 2023 Share Posted August 19, 2023 If you have one I would blast that with ac tig to pull the imperfections out of the castings before just hitting it with the spool gun. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 19, 2023 Author Share Posted August 19, 2023 1 hour ago, Bowie69 said: Filling the gap up with welding wire? That would be a lot of wire..... So no that is not the plan I have not discarded casting as yet..... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
