FridgeFreezer Posted August 22, 2023 Share Posted August 22, 2023 I believe the term is iterative development 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 22, 2023 Share Posted August 22, 2023 Improvement opportunities! 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 22, 2023 Share Posted August 22, 2023 Continuous iteration/continuous delivery. For the rest of us, not so sure about the last bit..... Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 22, 2023 Author Popular Post Share Posted August 22, 2023 So I think I'm winning, had a rake around in my metal stores ( read scrap ) and found some 50 x 8 aluminium flat bar Cut it Rolled it Tried for size clamped it Tacked it and started welding Unfortunately ran out of spool wire, I have some on a bigger reel, might have to wind some on I think this will look neater when finished, I will be milling the excess weld off to keep it all square I'm also going to go with @steve b's suggestion and use countersunk bolts, they should tie in nicely Regards Stephen 7 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 22, 2023 Author Popular Post Share Posted August 22, 2023 Wound the wire onto the spool gun spool and now fully Welded, waiting for it to cool so I can start machining Regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 22, 2023 Share Posted August 22, 2023 I feel like I’m getting a glimpse of how pioneering engineering worked I always though the first people up in planes must have been crazy - but I think they were just endlessly inventive and highly competent. Next week Stephen makes a mechanical fuel injection pump from microbore, a clock, and a 10” billet cube. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 22, 2023 Author Popular Post Share Posted August 22, 2023 Adaptor more or less finished, excess weld milled off Starter motor recess milled out All holes for 1uz side milled through, a couple are very close or through an edge but there is sufficient to countersink to, sent for a die as will need to make countersink bolts, will also reduce head diameter a wee bit so I don't have to go too wide with a countersink bit I may carry on and cast a piece as don't know if I'm totally happy with this effort Regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 22, 2023 Share Posted August 22, 2023 Do you do building work Stephen? I could really do with you operating at this speed on some of my projects... 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 22, 2023 Author Share Posted August 22, 2023 1 minute ago, Ed Poore said: Do you do building work Stephen? I could really do with you operating at this speed on some of my projects... From what I've seen your no slouch either... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 22, 2023 Share Posted August 22, 2023 That just isn't true... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 23, 2023 Author Share Posted August 23, 2023 Should probably start thinking about bench running this engine.... Have actually not done this before so any advice really welcome Regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 23, 2023 Share Posted August 23, 2023 Terribly dangerous thing to do... Don't advise it. But also: Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 24, 2023 Share Posted August 24, 2023 8 hours ago, Stellaghost said: Should probably start thinking about bench running this engine.... Have actually not done this before so any advice really welcome Regards Stephen With your capabilities I'd be inclined to knock together a bit of a support structure, even if it's just in wood onto a pallet to hold everything steady. Prior to dumping mine into a donor mockup chassis I had it on a pallet on some cheap heavy duty castors from ebay. Had blocks of wood wedged under relevant bits and big ratchet strap over it. Never fired it up as I hadn't sorted the fuel system but had it cranking over to test the ECU. Looked a lot more stable than @Bowie69s setup there. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 24, 2023 Author Popular Post Share Posted August 24, 2023 My electrical prowess knows no bounds, temp gauge now working huh, 1uz a walk in the park.....lol regards Stephen 6 3 Quote Link to comment Share on other sites More sharing options...
jad Posted August 24, 2023 Share Posted August 24, 2023 Is that "cold"? Mine is connected straight to the 109 guage and works pretty well! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 24, 2023 Author Share Posted August 24, 2023 1 hour ago, jad said: Is that "cold"? Mine is connected straight to the 109 guage and works pretty well! No, also its from my 200tdi, I had a wee bit of a moment at seven sisters compounded by the fact I had not wired up the temp gauge, but now it's done If you've read my mog axle thread you will discover I have an abject fear of electrickery.... Regards Stephen Quote Link to comment Share on other sites More sharing options...
ped Posted August 24, 2023 Share Posted August 24, 2023 it is a bit like witchcraft at times especially modern stuff Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 24, 2023 Author Share Posted August 24, 2023 7 minutes ago, ped said: it is a bit like witchcraft at times especially modern stuff Yes.....so if you would all like to keep your spell books handy....... Regards Stephen 1 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2023 Author Share Posted August 25, 2023 Machined down a 12mm countersunk bolt, this one is too short so will have to get some longer ones I can thread Turned down the diameter of the head and also took 1mm off the face I think that should do Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 25, 2023 Share Posted August 25, 2023 Not sure I'd want a countersunk head so small going into ali. At that stage I reckon you'd be better with a counterbore and a cap head. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2023 Author Share Posted August 25, 2023 1 minute ago, landroversforever said: I reckon you'd be better with a counterbore and a cap head. I would if it was solid all the way through, but it isnt, will see now I get on, have not abandoned the cast idea yet Regards Stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 25, 2023 Share Posted August 25, 2023 A shallow head cap would fit in the space you’ve got that, but without the angle. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 25, 2023 Share Posted August 25, 2023 Silly question, can't you build up the sides with weld to give you more Ali so you don't have to trim the counter sink off? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 25, 2023 Share Posted August 25, 2023 Do you need those ones to be bolts or can you use something like wheel studs which are a press fit into the ali? Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 25, 2023 Share Posted August 25, 2023 24 minutes ago, Ed Poore said: Do you need those ones to be bolts or can you use something like wheel studs which are a press fit into the ali? A stud into Ali sounds a bit dangerous as you run the risk of it spinning when you try to undo x years down the line Quote Link to comment Share on other sites More sharing options...
