What about something like this to make your cover from?
https://www.anchorsupplies.com/genuine-ex-british-army-heavy-duty-cut-canvas-tarp-cover-18ft-x-12ft.html
We had a canvas tarp made up for this sculpture we built, the fabric was super expensive.
Your build is great Stephen! Helps twist my arm to get more done on mine!
  • Like 1
  • Thanks 1
2 hours ago, Peaklander said:
I honestly can't keep up with this, the work is being done so quickly.
Thanks
Although I've been taking myself to task for being too slow of late !
Do you work a 4 on 4 off, 12 hour pattern? Otherwise I don't know how you do it!
I work a 3 on 3 off 12 hour pattern
Regards Stephen
  • Like 1
4 minutes ago, Stellaghost said:
err not wired up yet........
regards Stephen
On the plus side everything else will be done when you do pick up the scotcloks* and insulating tape:)
* I'm 100% sure you will do it to the same standard as the rest of this great build and there are no scotchloks anywhere in your workshop;)
Steve
  • Haha 1
Steve
Not a fan of scotchlocks
Regards Stephen
  • Like 1
Some of this build has been a bit of a blur - like your chassis work seemed to be about 4 or 5 weeks work and ended up taking you around 15 minutes.
It’s like watching a TV Boxset, where I’ve seen every episode, but I’m convinced I’ve missed some.
  • Like 1
  • Thanks 1
Regards Stephen
Me neither, I will not use them or let a client vehicle through the workshop without removing them and terminating a connection properly.
...it was meant as a tongue-in-cheek bit of humour of course
Steve
