9 hours ago, Bowie69 said:
Hey Stephen,  saw this earlier and thought of you (if that's not innappropriate):
Not sure if that would save you some time or even be possible?
Well thought, however I have purchased a 6 mm titanium coated blue coloured end mill that i've tested out on a piece of cut off shaft and it cuts it easy enough so I now have a back up once again thanks, keep that thought process going lol regards Stephen
  • Like 1
3 minutes ago, dangerous doug said:
When I started doing this many many years ago I used D2 front arms as they have a bit more room between the bushes
They could be an option if I can find out the dimensions, however at the moment I'm looking at making a single link arrangement regards Stephen
I think you have done right adding the extra meat to the axle, dunning and Fairbank at Leeds got me new needles and cups for my mog axles(416) when mine were knackered saving me over a grand on merc parts.
Fantastic work, so simple but needs so much skill and patience to actually get right.
  • Like 1
  • Thanks 1
A lot of work today but not a lot to show for it
First off a CAD ( compass assisted drawing )
then drilled out in an unwanted section a trial hole for metalastic Bush fitting
Slightly undersized but can be enlarged Slightly with a flap wheel unless I can pick up a 50 mm reamer at a reasonable price
Tacked both sections together for drilling, how heavy really
Drilled and split apart
9" grinders and slitting discs are amazing
so as I said not a lot to show but hours of work regards Stephen
  • Like 1
6 minutes ago, steve b said:
....those see through wheel guards for grinders are great for visibility ....:ph34r:
Guilty as charged your honour
7 minutes ago, steve b said:
could you use a fly cutter in the mill to size the bush holes ?
Steve
Been thinking about that I'll have a look at some regards Stephen
18 minutes ago, Bowie69 said:
The dedication here... astounding.
Thank you, obviously I have no choice, it ain't going to happen if I just stand looking at it, once you start you have to see it through, have to say I don't think you ever truly take in the amount of work  required when you look to start a project regards Stephen
Start at A  when it's done you can have a very nice ZZZZZZZ😴
And start the next stupid idea😋
