Stellaghost Posted August 8, 2021 Author Share Posted August 8, 2021 (edited) 10 hours ago, ThreePointFive said: I love everything about what you're doing, please keep the updates coming. 32 minutes ago, miketomcat said: So yes please keep it up. Mike Fully intend doing exactly that guys regards Stephen Edited August 8, 2021 by Stellaghost Addition 1 2 Quote Link to comment Share on other sites More sharing options...
Carloz Posted August 8, 2021 Share Posted August 8, 2021 (edited) On 8/6/2021 at 10:53 PM, De Ranged said: I love that comment, it is about the journey of building it.... the fun of solving the problems When you farm out jobs it becomes more about finishing than the journey and in my case takes a bit of sparkle out of the whole project lol keep up the good work Oh and I'm with Mike, you have plenty of strength in that.... and worst case if it does go it will bend not brake due to the material choice (the fact you drilled it shows its not something silly like Bis).... my only piont of interest is the bushes, your going to get an increased leverage due to the portals, it will be interesting to see how long there service life is Yeah, of course, but there will be more than enough to work out yourself! There must always be some sort of balance between effort and costs even within a hobby. And yes, I prefer also to do it all by myself. The machined piece on it self looks strong enough but the point where it connects to the 50x6mm is a weak point, it needs bracing there. The forces will be enormous even more with portals: that makes the same effect as wheels with a diameter in the region of 1,2M/47"... Or drive like an old lady of course... And yes, I really like projects like this a lot! Edited August 8, 2021 by Carloz Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 8, 2021 Share Posted August 8, 2021 16 hours ago, Stellaghost said: How much do you want for it John If you want it it's yours, everything's got to go or be skipped so much better send it to a good home! I'm sure we can work a forum relay at some point. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 8, 2021 Author Share Posted August 8, 2021 (edited) Simple job today, knocked up the 30x2 threaded boss for my Rose joint, could not use the existing boss as down on diameter for mating up to radius arm pipe diameter plus it is hollow I think solid bar will be much stronger, not much to look at on pictures I'm afraid regards Stephen Edited August 8, 2021 by Stellaghost 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 8, 2021 Author Share Posted August 8, 2021 (edited) 6 hours ago, miketomcat said: When I built my ibex I did a thread for pretty much the same reason Stephen does, to document and allow others to chip in. Mike ^ This is so important for me, I do believe, even if a post / thread is far removed from what you are actually doing you can pick up a snippet or learn something that could be recalled at a later date even if you can't remember where the thought was initially conceived. I would p!ead with all to post projects because speaking for myself I learn a hell of a lot about stuff that's out of my comfort zone but also stuff that's in my comfort zone. Two heads are better than one fits the bill perfectly regards Stephen Edited August 8, 2021 by Stellaghost Predictive pain 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 9, 2021 Author Share Posted August 9, 2021 If you look closely you can see a suspension component in the picture No not got it yet.... regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 9, 2021 Share Posted August 9, 2021 5" round? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 9, 2021 Author Share Posted August 9, 2021 4 minutes ago, Bowie69 said: 5" round? 4 1/2" regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 9, 2021 Author Share Posted August 9, 2021 That's it for tonight anyone figured it out yet Faced off pilot drilling final hole at 2" I love this drill !! goodnight regards Stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 10, 2021 Share Posted August 10, 2021 I’m thinking the threaded section for the rose joint will slip/press in there and be welded up? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 10, 2021 Share Posted August 10, 2021 Ohhhh or are you making a clevis for the chassis end? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 10, 2021 Author Share Posted August 10, 2021 12 minutes ago, landroversforever said: Ohhhh or are you making a clevis for the chassis end? Like I said earlier you really are a bright lad, spot on Ross, this will also incorporate rubber bushing as dampening, going to be a bit long winded turning it down but I would rather it was all made from one piece without welding regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 10, 2021 Share Posted August 10, 2021 Why the rubber bushing if you’re going to be using that rose joint? Will it not just allow it to move about? And take away the locating properties of the rose joint? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 10, 2021 Author Share Posted August 10, 2021 29 minutes ago, landroversforever said: Why the rubber bushing if you’re going to be using that rose joint? Will it not just allow it to move about? And take away the locating properties of the rose joint? The rubber bushing is an industrial coupling rubber cut in two and will be located into cups at the chassis end so should be no movement other than a slight give under severe loading which should be enough that the additional weight of the axles doesn't stress the chassis, it's just another idea I'm looking at at the moment I'm conscious that the chassis attatchment points will also need to be made stronger so by incorporating a wee bit of dampening I'm hoping to protect the chassis as well for any shock that affects the chassis outside strengthened areas It has been mentioned through out this thread that stress and loading due to the weight of the axles needs to be accounted for I guess I'm just trying to do that in all areas Your comments as always gratefully received regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Wytze Posted August 10, 2021 Share Posted August 10, 2021 I just have to say it again.. I like the way you think and work. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 10, 2021 Share Posted August 10, 2021 3 hours ago, Stellaghost said: The rubber bushing is an industrial coupling rubber cut in two and will be located into cups at the chassis end so should be no movement other than a slight give under severe loading which should be enough that the additional weight of the axles doesn't stress the chassis, it's just another idea I'm looking at at the moment I'm conscious that the chassis attatchment points will also need to be made stronger so by incorporating a wee bit of dampening I'm hoping to protect the chassis as well for any shock that affects the chassis outside strengthened areas It has been mentioned through out this thread that stress and loading due to the weight of the axles needs to be accounted for I guess I'm just trying to do that in all areas Your comments as always gratefully received regards Stephen I'm sure it will all make sense, I'm just trying to picture how it will stay located whilst also having that 'give'. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 10, 2021 Author Share Posted August 10, 2021 8 hours ago, landroversforever said: I'm sure it will all make sense, I'm just trying to picture how it will stay located whilst also having that 'give'. I've got the picture just need to convert it from skull to metal and see if it works regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 10, 2021 Author Share Posted August 10, 2021 Managed to get a bit more done tonight I did say it would be a bit of a long slog First off I attacked my hole with a 9" grinder ( oops sounds a bit oo errr ) then into Mill had to angle Mill head initially as not enough height below cutter Then got one flat side done regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 10, 2021 Share Posted August 10, 2021 Wow, definitely not under-built Reminds me of the occasion when, pushed for time building the racer, Vince machined a set of dislocation cones from solid whilst at work 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 10, 2021 Share Posted August 10, 2021 1 hour ago, FridgeFreezer said: Wow, definitely not under-built Reminds me of the occasion when, pushed for time building the racer, Vince machined a set of dislocation cones from solid whilst at work Thankfully it was usually Ali but my old boss was terrible for just giving us stupid sized bar to turn stuff. Bits 10-12mm OD….. from a bit of 6 or 7” bar Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 11, 2021 Share Posted August 11, 2021 Your swarf is probably more heavy duty than some of the suspension components you can buy for land rovers. Brilliant work ! Fascinated to see what you do with the chassis to fit it all together. 2 1 1 Quote Link to comment Share on other sites More sharing options...
Badger110 Posted August 11, 2021 Share Posted August 11, 2021 I was tad disappointed as I thought you were going to make a spring out of that lump.. ..or is that next weeks job 😂 quality work work as usual Stephen 👍 1 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 11, 2021 Share Posted August 11, 2021 3 minutes ago, Badger110 said: I was tad disappointed as I thought you were going to make a spring out of that lump For his ballpoint pen? 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 11, 2021 Author Share Posted August 11, 2021 Wee bit more done but work stopping play for today Finished on the Mill Going up the drills for pin hole finishing off with 30mm reamer last bit for today setting up in 4 jaw ready to start machining in the morning regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 11, 2021 Author Share Posted August 11, 2021 51 minutes ago, landroversforever said: For his ballpoint pen? Nige is not going to be happy with you lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
