landroversforever Posted August 11, 2021 Share Posted August 11, 2021 Are you going to end up with a radius at the bottom of the clevis? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 11, 2021 Author Share Posted August 11, 2021 1 hour ago, landroversforever said: Are you going to end up with a radius at the bottom of the clevis? I certainly am regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 12, 2021 Author Share Posted August 12, 2021 Did anyone mention swarf ........ Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 12, 2021 Author Share Posted August 12, 2021 (edited) More done this morning, work interfering for any more today Turned large diameter down to 42mm then Turned a short section down at the end to take an m24 thread, this became interesting as I did not have an insert for lathe tool but I do have an m24 die nut.... have you tried starting a large thread with only a large adjustable spanner.... not going to happen, step in Mill head and table, used them to apply pressure and keep thread square whilst cutting threads so you should be able to see where I'm going with this some more work to do but it's just about there. I did say there was a suspension component in there if you looked closely lol regards Stephen Edited August 12, 2021 by Stellaghost Addition 1 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted August 12, 2021 Share Posted August 12, 2021 There isn't that much metal in my entire 90 as you have in swarf. Quote Link to comment Share on other sites More sharing options...
Daan Posted August 12, 2021 Share Posted August 12, 2021 Good to see you keep the light weight theme going... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 12, 2021 Share Posted August 12, 2021 3 minutes ago, Daan said: Good to see you keep the light weight theme going... Weren't lightweights heavier than a standard series anyway? So using the Land Rover logic this will be a Super Lightweight 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 12, 2021 Share Posted August 12, 2021 M24 😮 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 12, 2021 Share Posted August 12, 2021 13 minutes ago, Anderzander said: M24 😮 I've got some stainless M30's in the shed, we used to bolt up oyster chain plates with them. Mike Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 12, 2021 Share Posted August 12, 2021 I used M30's bolting my hydraulic press together .... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 12, 2021 Author Share Posted August 12, 2021 26 minutes ago, CwazyWabbit said: I used M30's bolting my hydraulic press together .... Nice I would like to play in your workshop pleeeeeesssse regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 12, 2021 Author Share Posted August 12, 2021 (edited) 1 hour ago, Anderzander said: M24 😮 anything bigger would be overkill do you not think lol regards Stephen Edited August 12, 2021 by Stellaghost Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 12, 2021 Share Posted August 12, 2021 56 minutes ago, CwazyWabbit said: I used M30's bolting my hydraulic press together .... Okay - I didn't make my current hydraulic press but I take your M30 and raise you a 3" AF. I even had to make a special spanner for them 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 12, 2021 Share Posted August 12, 2021 This smacks ever so slightly of that old phrase 'willy-wanging' -pretty funny too! 😆 2 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted August 12, 2021 Share Posted August 12, 2021 16 minutes ago, Ed Poore said: Okay - I didn't make my current hydraulic press but I take your M30 and raise you a 3" AF. I even had to make a special spanner for them @Hybrid_From_Hell you still have those bolts I gave you😂 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 12, 2021 Author Share Posted August 12, 2021 I've got bigger nuts than most... but I'm not going to play regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted August 12, 2021 Share Posted August 12, 2021 May have you beat on this one…that’s an m12 on the flank of the nut😂 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 12, 2021 Author Share Posted August 12, 2021 5 minutes ago, dangerous doug said: May have you beat on this one…that’s an m12 on the flank of the nut😂 Oh dear.......... Mog axle nut fest.......... regards Stephen Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 13, 2021 Author Popular Post Share Posted August 13, 2021 (edited) Not much time today but managed to roll cups for rubber coupling half's to squash and locate into Couple of bits of 25 x 5mm flat bar add one home made bar roller and end result regards Stephen Edited August 13, 2021 by Stellaghost Spelling 6 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 14, 2021 Author Share Posted August 14, 2021 Concave cut into bottom of clevis Set up in 4 jaw Drilling Done I won't be using that bolt will be turning a pin down on the lathe regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 16, 2021 Author Share Posted August 16, 2021 I am acutely aware that some of you will struggle with this concept on this build Lightening regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Badger110 Posted August 16, 2021 Share Posted August 16, 2021 Tis a thing of beauty knowing what it came from, top stuff 2 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 16, 2021 Share Posted August 16, 2021 Looks great Stephen. Certainly looks more finished with the ends radiused. Back to my previous thought, I was meaning radii at the bottom of the clevis, where the square tabs meet the round base-like part. Have they only got a small cutter sized radius? Any concerns on cracking in the corners? What is the clevis/rubber area using to stop rotation and or flopping about under load? Are you going to have it keyed in some way and then only able to slide along it’s axis? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 16, 2021 Author Share Posted August 16, 2021 17 minutes ago, landroversforever said: Looks great Stephen. Certainly looks more finished with the ends radiused. Back to my previous thought, I was meaning radii at the bottom of the clevis, where the square tabs meet the round base-like part. Have they only got a small cutter sized radius? Any concerns on cracking in the corners? What is the clevis/rubber area using to stop rotation and or flopping about under load? Are you going to have it keyed in some way and then only able to slide along it’s axis? Thanks As it stands at the moment the radii at the bottom of the clevis legs is what the cutter is, I don't have a radius cutter at the moment, I have no concerns with it cracking as it's not going to get a massive amount of work and the give in the suspension will protect it to a degree, have not considered a key to locate clevis at the moment as I've machined it so that the m24 when tight compresses the coupling rubber to prevent movement however I will keep what you've said in mind when I put it all together and see where I'm at regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 16, 2021 Author Share Posted August 16, 2021 Not that I need it now, but it may come in useful in the future and for £12 I'm not complaining regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
