6 minutes ago, FridgeFreezer said:
If it's light it doesn't need to be as strong, virtuous cycle...
I know,  i just like old and bulky tech. And allthough SJ's and Jimny's are good fun..  I can't feel them like a nice Series like your's or Sid and a few more on here..  Just my taste.. Even my motorbike is a heavy one with it's 240 kg😁
1 minute ago, Bowie69 said:
I'm sure you could knock up a nice extended tub, given an afternoon or two :)
Looks more like you have 110 degrees anyway ;)
If I extend the tub I will also need to extend the chassis, will need new capping....
Anyway what's wrong with a bobtail lightweight.......
Regards Stephen
  • Like 1
A wee bit of mock up with body, seat box and bulkhead, but first some needs must modifications to my battery box
because nuke mount in the way
passenger side bulkhead outrigger needs to be moved up around 12mm
drivers side
Passenger side
on a more positive note  wheel rim modifications look to have paid off, I think this looks OK, will only need to extend rubber wings around 30mm
Thoughts regards Stephen
  • Like 3
Remember these sheets of 3mm aluminium from my raw materials boost, they are 110cm x 90cm going to use them to make a new tub bottom and sides 100mm narrower than stock this will keep suspension modifications outside the rear tub altogether
Regards Stephen
  • Like 2
56 minutes ago, Stellaghost said:
I take it the little green things load bay is massive...lol
Neither you or me are going to be moving loaded pallets around....
Regards Stephen
With no tailgate at all, I would agree ;)
Plus, the wheel boxes are essentially decorative, anything more than a fuel can and I reckon it would go through :D
Great idea on the new tub floor/sides, will keep all the muddy bits the right side of the interior. Have you not got anything thinner than 3mm? (Little Green Thing rubbing off on me a bit....)
10 minutes ago, Bowie69 said:
have you not got anything thinner than 3mm? :D
Might have, will need to consult my plate store tomorrow..
I'm not overly bothered about the weight at the moment, will need to see how it performs, at the moment it's more important to get it together and see what does and does not work, lightening can be done over time at some point in the future regards Stephen
  • Like 3
11 hours ago, Stellaghost said:
Might have to consult my plate store tomorrow
Plate store consulted...
I have a sheet of 2mm aluminium which I can use, I have some 1mm but that will not be strong enough me thinks to withstand stuff getting chucked in the back also I want to keep the 1mm in case I need to make panels for my future double cab project
At least with the 2mm I will minimise joints as I can fold to more of less fit the whole of the tub regards Stephen
  • Like 3
3 hours ago, Anderzander said:
Not quite following..
Do you mean the tub floor will be 100mm narrower with the wheel boxes 100mm wider?   Or are you changing the outside dimensions ?
3 hours ago, Bowie69 said:
That's how I understood it, leaves room outside the tub for his shocks.
Yep shocks will be outside going to fold a new tub floor and wheel boxes regards Stephen
  • Like 3
