mad_pete Posted March 22, 2018 Share Posted March 22, 2018 Pulling the dash out has provided a treasure trove of possible jobs. My wipers do occasionally park randomly up the dash so I was thinking new gearboxes for them. Where is the best place to get the from? Everything seems to be in a blue box priced £8- £26 that I have found. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted March 22, 2018 Share Posted March 22, 2018 I've got a couple of later puma wiper boxes here from Allmakes - they look good quality. Going to see if I can swap them for my earlier ones as they don't use the annoying separate splined spindle to hold the wiper arm on, just needs the later arms. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 22, 2018 Share Posted March 22, 2018 Genuine wheelboxes are cheap and easily available - they would be my vote after poor experiences with aftermarket ones. The later (2002-on) wheelboxes with the threaded spindles have a different sized gear and so the sweep will be different, if fitting to an older vehicle you will need to update the crank gear in the wiper motor at the same time to maintain the swept range of the arms. The rest of the motor is the same. 1 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted March 23, 2018 Share Posted March 23, 2018 Thanks for the heads up Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted March 24, 2018 Share Posted March 24, 2018 On 22/03/2018 at 10:23 PM, Retroanaconda said: Genuine wheelboxes are cheap and easily available - they would be my vote after poor experiences with aftermarket ones. The later (2002-on) wheelboxes with the threaded spindles have a different sized gear and so the sweep will be different, if fitting to an older vehicle you will need to update the crank gear in the wiper motor at the same time to maintain the swept range of the arms. The rest of the motor is the same. The earlier motor does actually run slower than the later type motor- If you use the later wheelboxes on an earlier motor and update the crankgear, the wiper speed is slower than a newer motor - my Puma 90 slow speed setting is almost as fast as my updated 300tdis fast setting. Quote Link to comment Share on other sites More sharing options...
