Troll Hunter Posted March 22, 2018 Share Posted March 22, 2018 In prepping body panels for spraying I have found there are a number of internal locations where LR used a non-hardening, black mastic to seal between panels, particularly where aluminium/steel contact could occur. What is this, please, and where can I buy it, or what is an acceptable alternative? Many thanks for any info and suggestions. Mike Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted March 22, 2018 Share Posted March 22, 2018 (edited) Perhaps Tiger seal or soudal polyurethane. I had boxes and boxes of the soudal, I used it for all sorts but then it all set in the tube and I had to skip it Really really sticky. Edited March 22, 2018 by Cynic-al Quote Link to comment Share on other sites More sharing options...
western Posted March 22, 2018 Share Posted March 22, 2018 car body seam sealer from local motor factors, I bought 2 tubes a while ago, it's labelled tigerseal. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted March 22, 2018 Share Posted March 22, 2018 Note that tigerseal sticks like sh*t to a blanket, so don’t expect to get it apart without a struggle if at all. We used it on a bow thruster when the sealing surfaces were beyond machining. No leaks! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 22, 2018 Share Posted March 22, 2018 The land rover goo is not a polyurethane (tigerseal sikaflex etc) but these will do the job provided you don't need to get the joint apart again. Arbo do a polysulfide (arbokol) and a mastic (arbomast). The former is half way between rubber seal (sika) and mastic. Arbomast we use on rudder heal fittings so its water tight but can be removed easily but it is sticky and messy. Mike 1 Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 23, 2018 Share Posted March 23, 2018 I remember reading somewhere that the stuff they used to use is now obsolete, and that 3M caulk strip was the modern alternative. I used some on the windscreen to roof joint on my hybrid and it seemed to do the job nicely. The other favorite of mine for little gaps is RTV silicone. Gets into all the little gaps and seals well, but still half a chance of getting it out again. I only use PU adhesive (sika, tiger) for anything that will never be coming apart again. Quote Link to comment Share on other sites More sharing options...
paintman Posted March 23, 2018 Share Posted March 23, 2018 Do a Google search for 'butyl sealant strip'. Arbo will come up as will many others. Comes in various sizes. I use the round strip for sealing weather shield plastic sheets door frames. Sticks like the proverbial but you can get things apart if necessary - although as said above it's messy! Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted March 23, 2018 Author Share Posted March 23, 2018 Thank you, all, for the info and suggestions. Having the appropriate description I've already found a local supplier of butyl tape. I want to retain the option of possible removal, perhaps in another 20+ years, although it won't be me doing it, so I'll keep away from the Tigerseal type products. Mike Quote Link to comment Share on other sites More sharing options...
mickeyw Posted March 23, 2018 Share Posted March 23, 2018 8 hours ago, paintman said: Do a Google search for 'butyl sealant strip'. This is what I used to re-seal my floor panels. Not too mucky to handle, and squashes into the gaps, allowing for the varied gap widths. Not too much of a pain to get apart again either. Quote Link to comment Share on other sites More sharing options...
Kurt Posted April 2, 2018 Share Posted April 2, 2018 Was going to chime in with a suggestion of Eldro Dum Dum but a quick google search points to it being no longer available.... Quote Link to comment Share on other sites More sharing options...
