Gazzar Posted April 1, 2018 Share Posted April 1, 2018 I was given this by a friend. I'm going to paint my lightweight army green, will this do? Can I get more? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 1, 2018 Share Posted April 1, 2018 If you want authenticity, open can and pour it over the truck from above, leave to drip dry. Normally military vehicles weren't gloss, but that's up to you. Quote Link to comment Share on other sites More sharing options...
qwakers Posted April 2, 2018 Share Posted April 2, 2018 cheap spray gun from screwfix and a compressor and off you go. you could roll it on but i personally cant stand the finish that gives. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 2, 2018 Share Posted April 2, 2018 Exactly as Bowie69 posted Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 2, 2018 Author Share Posted April 2, 2018 As it's 2k do I need an activator? Are there different types? Quote Link to comment Share on other sites More sharing options...
qwakers Posted April 2, 2018 Share Posted April 2, 2018 yes, there are two types of 2k that i know of but the age those tins look it should be standard stuff https://www.jawel.co.uk/index.php?main_page=product_info&cPath=74_92&products_id=2673&zenid=l440cos095biq0b51jksh7d9a3 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 9, 2018 Author Share Posted April 9, 2018 Perfect, all I need to know. Thanks, all. G. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted April 9, 2018 Share Posted April 9, 2018 Does it have a mix ratio anywhere on the tin? "Most" basic 2k is 2:1 paint to hardener (or activator), you'll also benefit from a dash of thinners (between 5-10%). You may find without the thinners that it won't spray well, especially if using a smaller tip spray gun....and make sure to stir really well if it's been sitting some time as a lot of the solids will be lying on the bottom of the tin. Another thing to do if your using both tins is to mix them both together to ensure a consistent colour. It may not matter much on olive drab, but if you want a decent finish its what I'd do. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted April 9, 2018 Share Posted April 9, 2018 Oh, and get a really good mask if you don't have airfed. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 11, 2018 Author Share Posted April 11, 2018 That's really good advice. I need to get the air system in the workshop all sorted, air fed masks will feature in the design. Thank you. G. Quote Link to comment Share on other sites More sharing options...
qwakers Posted April 11, 2018 Share Posted April 11, 2018 i know this may well be granny sucking eggs territory BUT! when locating compressor (if multi compressor system then the one that feeds the masks) make sure its air inlet is NOT in the same location in which you are spraying. i have seen that done, and the guy who though he had done everything right now has to have a oxygen supply permanently attached to live... Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 11, 2018 Author Share Posted April 11, 2018 It's a good point, but I've put a lot of thought into the air intake and filtering for the air plant room. Trying to cool the room, heat the workshop and supply clean cold dry air to the compressor is a fun puzzle in boring meetings. With winter and summer settings! G. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted April 12, 2018 Share Posted April 12, 2018 I built a compartment sealed from the workshop and supplied it with fresh air from outside. Did the job Quote Link to comment Share on other sites More sharing options...
